Locating Wall From Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2014, 01:37 AM   #1
Rewards Points: 512
Was up in an attic the other day, and no visible signs of the ceiling header.
Idea, of course, was to find an inside wall to be able to drop a cable to a receptacle. Wasn't hard to find in this case, because there was a switch on the opposite wall, and I located the leg for it. But there was no header (!); only a hole through the ceiling drywall. It went where it was supposed to, but why was there no header? I'm lost.
Installation is the Reverse of Removal.
Old 05-09-2014, 04:32 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
The wall is not load bearing and was installed after the drywall was hung.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
oh'mike (05-09-2014), plummen (05-09-2014), sirsparksalot (05-11-2014)
Old 05-09-2014, 08:31 AM   #3
joed's Avatar
Rewards Points: 13,330
If the interior wall was installed after the house was built then the header will be below the drywall.
Well not really a header but a top plate.
The Following User Says Thank You to joed For This Useful Post:
Old 05-09-2014, 02:31 PM   #4
Rewards Points: 336
A joed says, "top plate" is likely the correct term for what you are describing. A header is a load-bearing member that spans across framed openings in walls, such as doors and windows. His description of how this wall might have been built is entirely plausible.
JKeefe is offline   Reply With Quote
The Following User Says Thank You to JKeefe For This Useful Post:
Old 05-11-2014, 04:46 PM   #5
Rewards Points: 512
Such a simple explanation. Thanks guys.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Insulating attic wall shared with living space BlueBSH Insulation 2 07-12-2012 11:04 PM
Wires from attic to spot in the wall jdimuzio Electrical 5 03-21-2011 11:34 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
