Locating A Wall From Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 02:54 PM   #1
Locating a wall from attic
I bought a HDTV antenna and plan to install it in the attic. I'd like my TV in the family room to hook up to it. My problem is when I am in the attic (it's a fairly big and open attic), I am not able to find exactly where the family room wall is. My goal is to find the wall, drill a whole from the top plate and drop the wire down to reach the bottom of the wall, where I would install an outlet.
Just exactly how I locate a wall from attic? Any trick/tips?
Thanks!
penn10 is offline   Reply With Quote
Old 08-15-2011, 03:19 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 534
Walls go to the bottom of the rafters, so you could get a general idea, move the insulattion around and find the top plate.
If the A/C vents from the ceiling, you could measure from them to the wall and those you can find in the attic.
A metal coat hanger pushed through the ceiling can be easy to find, if it is long enough, and the hole can be filled with spackle afterward.
The Following User Says Thank You to jbfan For This Useful Post:
electures (08-16-2011)
Old 08-15-2011, 03:58 PM   #3
Experienced
Jackofall1's Avatar
Tooth paste works good to for filling small holes such as the one left by a coat hanger.
Mark
Old 08-15-2011, 05:02 PM   #4
biggles's Avatar
from the living room up on a ladder punch a rod up thru the ceiling above where you want the connection and new box to be behind the TV.or probe from the room behind the living room wall..either punch up will give you your drill down opening to drop the cable between studs.
Old 08-15-2011, 05:21 PM   #5
Rewards Points: 6,652
Keep in mind, depending on how far you are from the stations that you plan on picking up, the antenna you choose, can make a difference.
http://antennaweb.org/aw/welcome.aspx
Old 08-16-2011, 03:23 PM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You can also look for other wires going down the wall for existing receptacles, switches, CATV and such. Use these as a reference. Drill down through the top plate. Tie a small washer on a string. Tie the string to the cable and drop it down the wall. Use the hole for the old work box (or what ever you use) to grab the string and pull it out of the wall. INstall box and plate. Good to go!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-16-2011, 03:31 PM   #7
Or they can use the existing coax from catv if it is up there. Some installers have a tendency of placing the coax block up in attics. The one thing that irks me, is when people want to place their networking gear up in attic. Right now, it is 93 up in mine. I have seen it get as hot as 131, when we had the heat wave.
Wires from attic to spot in the wall jdimuzio Electrical 5 03-21-2011 11:34 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
To seal/cap a wall with plumbing in it, or not... bkraz Plumbing 1 12-14-2010 09:32 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
