Old 10-09-2012, 11:51 AM   #31
Licensed Electrician
k_buz's Avatar
Locating Floating Neutral
If the POCO metered their lines with no load, they easily could have missed a bad neutral on their end.
Location...Location...Location
Old 10-09-2012, 12:19 PM   #32
Thadius856's Avatar
Originally Posted by Billy_Bob View Post
I get 1079 watts total, so that is not anywhere near the capacity of the wiring or circuit. Rule that out!
As for shorting the lug with the neutral, that would cause a "voltage surge" and voltage surges can damage some electronic devices.
So the question is, did this shorting happen at the same time the painter came? (Or did the problem crop up right after the shorting occurred?)
Surge was approximately or week before painting. I was making room for this circuit to be hooked up, so it wasn't connected yet.
Check out my on-going
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Generator & Interlock Kit – Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 06:28 PM
Need Neutral Connections - Installing Subpanel ctlu008 Electrical 10 01-01-2012 08:54 AM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
