Locate Wiring In Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2007, 07:34 PM   #1
Locate wiring in walls
Hi;
Does anyone know of anything that will detect electrical cables (mostly metallic) in the walls?
When I Googled the subject, I found a post somewhere that said electricians use a compass. But I don't expect this would work with a cable that uses a steel jacket.
Most of the wiring in my old house is Armored, and I believe that it is steel.
That would most likely prevent the magnetic field from getting out.
I will try the compass anyway though.
FW
fw2007 is offline   Reply With Quote
Old 10-01-2007, 07:53 PM   #2
Edit:
I tried the compass, and as I had expected it did not work at all, on either AC or NM cable.
Since both the conductors are in the same cable, the net magnetic field is zero.
Way back when I was a kid living in a home with knob and tube wiring, I could always pick up the wiring in the walls using a telephone pickup connected to my tape recorder.
I guess I will be looking for something that will locate anything metallic.
FW
Old 10-01-2007, 08:30 PM   #3
Remodeler
MinConst's Avatar
There are stud finders that will also find cable, duct work etc.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 10-02-2007, 05:50 AM   #4
RippySkippy's Avatar
MinConst is right one Zircon has one, don't know how well it works. I have a smaller and older version that's supposed to locate wires...and it works fair. I would think newer stuff would scan deeper and better.
RippySkippy is offline   Reply With Quote
Old 10-02-2007, 09:23 AM   #5
I have an electronic stud finder. I'll see what it can do.
FW
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 06:25 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
