Loads - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 05:38 PM   #16
Originally Posted by kevinp22 View Post
The additional information helps. The problem with a clamp on meter is that you you have to be able to measure each conductor. If you put one of the extension cords or fixture cords under the clamp, the hot and neutral conductors will cancel out/give an incorrect reading.
Better to use the meter ddawg mentioned, then size your cords accordingly.
ok going to get it now.
R.j.D is offline   Reply With Quote
Dead Loads / Struct. Eng Ghengisconrad Building & Construction 34 06-16-2012 07:39 PM
new kid needs to chase loads toadtheninja Building & Construction 17 05-25-2011 01:16 PM
how to connect from meter to 3 loads. ahill Electrical 2 07-28-2010 12:27 AM
?Wiring to loads to same switch? Charlie123 Electrical 11 04-29-2010 06:31 AM
??? about calculating loads for a sub panel TKO204 Electrical 4 12-03-2009 07:58 PM
