Loadcenter Change - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 04:06 AM   #1
Loadcenter change
Is it ok to replace 100A 20 breaker 24 circuit loadcenter with 100A 30 breaker 30 circuit loadcenter? Old panel maxed out and have gone to piggyback breakers, need extra room in panel for new ATS wires. Both panels use BR breakers, new panel has copper bus, aluminum service cable is rated 100A and will not change. Load calc. looks ok for 100A. THANKS
wmmurphy is offline   Reply With Quote
Old 10-27-2010, 05:22 AM   #2
dSilanskas's Avatar
Yes your fine
dSilanskas is offline   Reply With Quote
Old 10-27-2010, 07:57 AM   #3
Licensed electrician
Rewards Points: 1,494
A less labor intensive option would be to install a subpanel.
is UG conduit size change legal? krazni Electrical 1 07-13-2010 02:17 PM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-04-2008 11:41 PM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 06:41 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 06:54 PM
