Load Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 10:19 AM   #1
load wire
The timer that I am installing has a black, red and white wire.The outlet that I am installing in on has only a white and black. How do I wire it.
Gary Kahn is offline   Reply With Quote
Old 11-09-2010, 10:36 AM   #2
Rewards Points: 240
Black is power for the timer. White is the neutral for the timer and the load. Red is the switched timer power for the load.
Old 11-09-2010, 02:29 PM   #3
Licensed Pro
Are you replacing a switch with the timer and the switch only has two wires?
If so, then it can't be done with that timer. It requires a neutral and you don't have one in that box.
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 01:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 07:23 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Load vs. line wire gvernea Electrical 5 01-16-2008 12:50 AM
