Old 01-15-2008, 06:10 PM   #1
Load vs. line wire
A delayed timer switch I am installing requires that a different wire be fastened to the "load wire" than to the "line." How would I determine which is which (both come into box at same side). Can I use a multitester?
gvernea is offline   Reply With Quote
Old 01-15-2008, 06:25 PM   #2
Electrician philosopher
Load vs. line wire
Yes. Check continuity.
Andy in ATL is offline   Reply With Quote
Old 01-15-2008, 08:41 PM   #3
Load vs. line wire
the terminal labeled line is the power coming into the timer and the line goes to the unit being turned on by the timer
mgv79 is offline   Reply With Quote
Old 01-15-2008, 09:42 PM   #4
Load vs. line wire
Continuity between which wires coming out of the box?
There is no terminal or label on the wires coming from the wall box, I know which wire coming from the switch is which. The black load wire from the wall box and black line wire are the ones I can't tell apart.
Old 01-15-2008, 10:38 PM   #5
Electrician
Load vs. line wire
The LINE wire would be the one with voltage on it, the load, well would be the device the line is suppling to...
chris75 is offline   Reply With Quote
Old 01-16-2008, 01:50 AM   #6
Load vs. line wire
I assume that this guy means you were joking?
Line side is the one with voltage. There could be continuity on either side.
Line = in, load = out.
220/221 is offline   Reply With Quote
Wire sizes based on actual connected load BigJimmy Electrical 7 08-21-2007 09:30 PM
10 gauge vs 12 gauge wire for 30 amp line hsdude1992 Electrical 5 06-30-2007 02:36 PM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 01:50 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
