-   -   Load vs. line wire (http://www.diychatroom.com/f18/load-vs-line-wire-15648/)
gvernea 01-15-2008 05:10 PM
Load vs. line wire
A delayed timer switch I am installing requires that a different wire be fastened to the "load wire" than to the "line." How would I determine which is which (both come into box at same side). Can I use a multitester?
Andy in ATL 01-15-2008 05:25 PM
Yes. Check continuity.:jester:
mgv79 01-15-2008 07:41 PM
loads
the terminal labeled line is the power coming into the timer and the line goes to the unit being turned on by the timer
gvernea 01-15-2008 08:42 PM
Continuity between which wires coming out of the box?
There is no terminal or label on the wires coming from the wall box, I know which wire coming from the switch is which. The black load wire from the wall box and black line wire are the ones I can't tell apart.
chris75 01-15-2008 09:38 PM
The LINE wire would be the one with voltage on it, the load, well would be the device the line is suppling to...
220/221 01-16-2008 12:50 AM
I assume that this guy:jester: means you were joking?
Line side is the one with voltage. There could be continuity on either side.
Line = in, load = out.
