-   -   Load panel and lights (http://www.diychatroom.com/f18/load-panel-lights-177995/)
kujo 04-24-2013 01:56 PM
I'm looking into replacing my load panel and most people seem to recommend cutler hammer panels so my question is is this a good one
Model #: CH42B200V
Also, I have four floodlights, one on each corner of the house. They are on two switches by the front door and operate as front and back. I am adding french doors on the side of the house and was wondering is it possible to wire the lights to do right side front and rear from a switch by that door. I read an article about a guy discussing this but he never said how he done it other than he tab an extra wire from the lights to give him front back and left right
Thanks in advance for your help
jbfan 04-24-2013 02:49 PM
If someone tells you that one brand of panel is better than another, it is just there opinion.
Depending on how the lights are wire, and how handy you are, you can make the changes you to on the lights.
OCPik4chu 04-24-2013 04:22 PM
Model #: CH42B200V
an overview answer to the 2nd question would be 'probably' You can replace the switches with 3-ways and run a wire between the existing switches and the new location. Some other folks here have some good diagrams for that sort of thing so I'll let them post it up to give a better picture.
stickboy1375 04-24-2013 04:37 PM
12 Attachment(s)
Try going wireless, if you can install a dimmer, you can easily do this change over yourself.
http://www.lowes.com/pd_30469-539-MR...cagpspn=pla%22
dmxtothemax 04-24-2013 06:15 PM
So what are you trying to do ?
Do you want an extra light switch,
in a different location ?
Do you want to reconfigure the lights from
the current front and back to side and side ?
Please elaborate ?
You were not very clear.
kujo 04-24-2013 06:43 PM
You need to get constant power to front and rear switch locations, then from switch location to corner light, then the other corner can run to switches or the first light, which ever is cheapest/easiest. It depends on the lay out of the yard to have mabe front and left? Side be switched from the front switches, and have the 2 rear switches control back yard lights and right side of the house. Depending on the yard, you may be better off with 3 switches at the front(Left, right, and front. If you had motions sensors wired for front, rear, left, and right, it would narrow down the location of an intruder.
< Page 2
Maybe I'm reading this wrong but sounds like he's talking about lights being wired to work front rear left and right
dmxtothemax 04-24-2013 08:12 PM
< Page 2
So he wants to seperate the two front lights ?
Easy !
Remove the hot line from one of the lights,
Cap it off,and,
run a new single hot line from the new
switch to the light.
Jumper the hot supply on the switchs input sides.
The existing neutral and earth at the light remain the same.
