Load KVa - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2012, 04:19 PM   #1
Load KVa
I am ready to submit an application for a new connection and have been asked to provide Electrical Load Requirements in KVa
I am building a small 3 bedroom property 5.4mtr x 9.3mtr and was wondering if anyone could assist with what i should insert.
Many Thanks
cul8rm8e is offline   Reply With Quote
Old 12-19-2012, 04:25 PM   #2
Rewards Points: 14,312
Go back and add your location to your profile, yes it really matters.
cul8rm8e (12-19-2012)
Old 12-19-2012, 08:46 PM   #3
Rewards Points: 1,548
Multiply the number of amperes you want/need to have available by the line voltage. Then divide by 1000. I think the UK uses 240 volts for all household branch circuits; all lights and appliances.
Or you can take the expected load in watts and divide by 1000.
Example: A building for which you expect to need 100 amps at 240 volts would have a load of 24000 watts aka 24000 VA or 240 KVA.
In a factory or other (usually commercial) building with a lot of motors i.e inductive loads KVA is computed a little differently but for residential use (mainly lights and electronics as resistive loads) you can start with just volts and amperes or start with watts.
The UK probably has a code book that includes how to calculate the expected load. The USA does have a code book, the National Electric Code, and load calculation includes such things as 3 watts for every square foot of living space.
The Following User Says Thank You to AllanJ For This Useful Post:
cul8rm8e (12-20-2012)
Balancing load while using a generator wavewuver Electrical 22 10-15-2016 06:40 PM
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 04:28 AM
Beware of Inappropriate Load Calculation Software - Source ACCA.org JJboy HVAC 5 09-06-2011 06:25 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 11:49 AM
More Accurate Load Calculation zootjeff HVAC 9 12-14-2009 12:06 AM
