Load Center For Residential. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 06:30 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That's all well and good, but most people don't ever turn off a breaker. Add to that the increasing mandates for costly AFCI breakers, and it doesn't make much sense for most people to have their wiring laid out like you like to.
Old 11-08-2013, 07:41 AM   #17
Master Electrician
Rewards Points: 3,864
Originally Posted by Speedy Petey View Post
You can use 1/2/twin/skinny/tandem breakers in any panel that will accept them. It's not just a GE thing.
Not all GE load centers accept GE THQP 1/2 size breakers. Oddly enough, I just observed a GE LC that only accepts full size breakers with a CH BR twin installed in it.
Sorry, I just reread the "that will accept them" portion of your post. My bad.
brric is offline   Reply With Quote
Old 11-08-2013, 08:34 AM   #18
Rewards Points: 774
I utilized Square D for my house and I think it is because the first residential EC I worked for only used Square D. As noted by others it is a Ford, Chevy thing with others swearing Dodge.
As long as Zinsco and Old FPE are not in the mix.
Know A Little is offline   Reply With Quote
Old 11-08-2013, 10:02 AM   #19
Rewards Points: 360
hey speedy , who else makes a skinny breaker besides the FPE? i can't seem to recall of any on else that does.i'm proabaly wrong, but rattle them off for me.
circuitman is online now   Reply With Quote
Old 11-08-2013, 10:04 AM   #20
Rewards Points: 360
yeap , i found that out the hard way , got a 30 space i belive & it only takes the 1 inch format.
Old 11-08-2013, 10:05 AM   #21
Rewards Points: 360
btw, i mean just the 1/2 ones.
Old 11-08-2013, 01:37 PM   #22
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
But that's not what I said, is it?
I said "1/2/twin/skinny/tandem". By this I mean two breakers in a typical 1" space.
For an actual 1/2" breaker I think FPE and GE are the only ones.
Old 11-08-2013, 03:58 PM   #23
Rewards Points: 360
he speedy , wasn't trying to contradict you, just making the point that there were only 2 real 1/2 breakers , & the piece of junk FPE is all but history.i agree with you on the tandem & twins, i always call the 1/2 skinny.
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
