Load Center For Residential. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 12:21 PM   #1
Load center for residential.
What is the best brand of load center for a residential home? And is Home depot a reliable source for load centers?
Sunofafrog is offline   Reply With Quote
Old 07-31-2011, 05:24 PM   #2
Asking which is best is like asking which make of truck is best, everyone will have their own opinion. As far as Home Depot goes, ask them what experience they have in the electrical trade. Some actually have experience, and some have no clue.
Sliver is offline   Reply With Quote
Old 07-31-2011, 06:34 PM   #3
Rewards Points: 6,652
My house has a Square D panel, same as my garage. It really depends on what your electrician uses when he rewires the home with the new panel, meter pan & rain head, and runs a new drop if needed.
Old 07-31-2011, 06:41 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
For residential use there is really not a bad brand out there right now. More than anything the panel layout is the deciding factor.
Sq D QO has great breakers for example, but I absolutely HATE the neutral/ground bar layout, which is why I only use them if necessary.
Sq D QO and Cutler-Hammer CH series are considered more top-of-the-line, but in real world experience I have not seen any appreciable difference across most major brands.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
mpoulton (11-08-2013), SD515 (07-31-2011)
Old 07-31-2011, 07:24 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
For the most part, I like the layout of the Siemens panel too. QO's are nice, but pricey. They all seem to have their good and not so good points. FWIW my house has a Square D Homeline.
Kyle
Old 11-06-2013, 08:15 PM   #6
homeline of the oringial squard d..i know the reg sq d coast more...but are they really better? tks
richard444 is offline   Reply With Quote
Old 11-07-2013, 03:59 AM   #7
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
copper BUS BAR .... i preffer Siemens the P series ..cause of the way all the bars are laid out ...not the ones that come in the contractor kits ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-07-2013, 05:44 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by Philly Master View Post
copper BUS BAR ....
I see this stated all the time. I've been in the trade 17 years now, and I don't think I've ever installed a panel with a copper buss. If a copper buss made that much difference, you would think that they would be much more popular.
Old 11-07-2013, 07:05 AM   #9
Really? I have a typical Siemens panel in my house (that I put in to replace an FPE). The buss is solid copper, but not clad like QO or others.
I also from time to time get Cutler Hammer BR series panels with a solid copper buss for certain installations. My supply house stocks a few.
Old 11-07-2013, 03:44 PM   #10
Rewards Points: 516
LOL even Home Depot has them .... look on the bottom shelf ....
Old 11-07-2013, 03:49 PM   #11
k_buz's Avatar
I'm telling ya, it must be a regional thing.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Speedy Petey (11-07-2013), stickboy1375 (11-07-2013)
Old 11-07-2013, 05:39 PM   #12
Rewards Points: 516
http://www.homedepot.com/p/Siemens-2...d#.Unwi_4U4m1A
LOL your right .. not in HD .. zip ..53704
but they do sell the 30 space ...
http://www.homedepot.com/p/Siemens-1...d#.UnwjiYU4m1A
Old 11-08-2013, 12:42 AM   #13
Rewards Points: 382
i like sguare D the best, but have used the homeline. i have a GE panel in my shop which i like because i can use the 1/2 breakers in this one.
circuitman is offline   Reply With Quote
Old 11-08-2013, 05:39 AM   #14
You can use 1/2/twin/skinny/tandem breakers in any panel that will accept them. It's not just a GE thing.
Old 11-08-2013, 06:08 AM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
The specs on your panel will determine if it accepts tandem breakers or not....
For example, I have the SD panel...it's listed as a 200A 20/40...which means it has 20 spaces but I can put up to 40 ckts in it.
I tend to like to distribute a lot of my loads....so I have quite a few of the tandem breakers in mine. I just like being able to shut down part of one room and not half the house...
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Philly Master (11-09-2013)
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
