-   -   Load Center Replacement - with or w/o main breaker? (http://www.diychatroom.com/f18/load-center-replacement-w-o-main-breaker-37174/)
shepiii 01-30-2009 12:06 AM
I will soon be having my old Federal Pacific load center replaced and want to know if I should spend the extra on one with a main breaker. It seems to add quite a bit to the cost of the new load center which I presume is because a 200a main breaker is quite expensive by itself. This for a 1,500 sq ft 2br townhome. I don't have a main breaker now and I really haven't needed it in the past so just wanting to know if it's something I should get. Recommendations?
wirenut1110 01-30-2009 06:59 AM
I'm pretty sure there's a main breaker somewhere. Maybe you have a split buss panel and you're not familiar with those.
Anyway, to answer the question, yes you need a main breaker panel unless there's a disconnect located outside possibly by the meter.
They're really not that expensive, a Square D 200 main breaker load center "value pack" is only around $150 and comes with 1-250, 1-230, 6-120, and 6-115 breakers.
Speedy Petey 01-30-2009 07:04 AM
Yup, I agree.
I would almost guarantee a remote main disconnect. This is typical of a town home.
You do not need a main breaker panel, although as nut said, they are NOT that much more expensive. Supply and demand.
jamiedolan 01-30-2009 12:04 PM
cuttler hammer ch panel with 200a main is a top of the line box only about $140 at menards. Comperable panels at HD for about. The same. Jamie
