Load Center Generater Interlock In Cook County, IL - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 09:14 PM   #1
Load Center Generater Interlock in Cook County, IL
Has anyone had any experience using a load center interlock to connect a generator to your load center in Cook County, IL? I know they are UL listed and meet the NEC, but I am curios if county inspectors are OKing them since they can be defeated by removing the panel cover. http://www.nooutage.com/interlock_kits.htm
shilohqdog is offline   Reply With Quote
Old 02-15-2011, 11:19 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Talk to them first before you do anything with it and IMO they are very strict on this one and I don't think they will allow it in your area.
I know in couple spot in Northeast Wisconsin area they are not allow to use that as well due one inspector say if someone remove the panel cover and the interlock can get defeated real easy.
In France they will not touch it at all it have to be a true transfer switch with full interlock feature in there.
Merci.
Marc
Old 02-20-2011, 03:57 PM   #3
120 volt only load center? rgsgww Electrical 28 01-29-2009 11:29 AM
Termite repair to load center wall - precautions shepiii Electrical 3 01-21-2009 04:14 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
Main Load center Size Evnldr Electrical 11 06-13-2008 10:10 PM
Load Center dwayne Electrical 4 07-09-2006 01:02 PM
