Load Center.. Final Inspection - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 06:28 AM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by busman View Post
This isn't a GE panel. The black and red are on the same phase. Also, it looks like Romex and MC cable in the same connector in two places.
Mark
Look agin. The mult wire is installed correctly.
Old 06-19-2012, 05:34 PM   #17
Master Electrician
Rewards Points: 3,920
I see your point, it is connected to two diferent tandems which are on different phases. It is NOT code compliant however.
I stand corrected. It is a two pole quad breaker. No problem.
brric is online now   Reply With Quote
Old 06-19-2012, 08:40 PM   #18
Rewards Points: 330
i think if you look,the bottom 5 stabs are notched.that is the only place tandems can go.those are non-compliant breakers.they don,t have the rejection tabs.yes?
oleguy74 is offline   Reply With Quote
Old 06-19-2012, 10:28 PM   #19
joed's Avatar
Rewards Points: 13,338
The panel info picture posted indicates 60 circuits max. That means the entire panel can be filled with tandems if needed. There are only 30 slots.
Old 06-19-2012, 10:48 PM   #20
Rewards Points: 330
aaahh see that.usually when stabs are straight not tandem.noched tandem.if in US,only 30 ckts.ul listing.
What is this piece of metal for in my load center? danielrg Electrical 6 05-23-2012 01:09 AM
Service Cable from Meter to Load Center monkeystomach Electrical 13 04-26-2012 08:19 AM
Expanding load center capacity in barn mn1247 Electrical 8 09-13-2011 08:24 AM
Installing new load center - do I have to buy AFCI breakers jerseyguy1996 Electrical 6 11-01-2010 09:29 PM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 11:49 AM
