Load Center For Barn - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 09:02 PM   #1
Mr. Handy
Rewards Points: 16
I have a barn that currently has a safety disconnect switch and I want to replace it with a load center.
The power for this barn comes from the utility pole...after the meter of course.
I believe the new load center should be a main breaker load center vs a main lug. Am I correct?
Wiring to the barn is overhead and is 2 hots and a neutral. Currently a ground wire and the neutral wire are connected to a ground rod next to the barn. Would this be proper moving forward with the new load center?
swiederin is offline   Reply With Quote
Old 02-04-2014, 09:32 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Simple thing to do ...curious .. was the safety switch fused ?
The barn has it's own service ? No residence on the property? Is this property zoned agricultural ?
Doesn't have to be .. most main lug panels have the option of having a backfed main installed anyways. I would recommend one for you but as a guide a main breaker 100 amp load center has around 20 to 24 circuits for single pole 120 volts. A 100 amp main lug will have 16 or less as a rule... so it depends on what you need to power and how many circuits you are going to need.
Not 100% sure what you mean but if your saying the neutral and ground are together in the safety switch ...then yes that is fine for 3 wire feeds.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-05-2014, 12:29 PM   #3
Rewards Points: 512
Stubbie, if the barn panel is a subpanel, or the "only" panel after the meter, doesn't it need a disconnect or a main breaker?
Installation is the Reverse of Removal.
Siemens Load Center Help - Bonding aquasport17 Electrical 4 10-24-2012 11:21 AM
Main load center grounding question. sgip2000 Electrical 18 10-03-2012 11:45 AM
Boxing In My Load Center? ddawg16 Building & Construction 5 08-22-2012 10:21 PM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
