Load Center With All Slots Full - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 12:46 PM   #1
load center with all slots full
How many different legitimate ways are there to add one more 15A or 20A circuit to the panel referenced above?
What are they?
TIA.
Old 06-04-2012, 12:49 PM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Check label to see if tandems are aloud.
Sub panel next to existing panel.
just a start.
Big N8 is offline   Reply With Quote
The Following User Says Thank You to Big N8 For This Useful Post:
Yoyizit (06-04-2012)
Old 06-04-2012, 12:50 PM   #3
Licensed electrician
Rewards Points: 1,010
What panel referenced above?
Old 06-04-2012, 01:12 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Do you have a picture of the panel label or the model number?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-04-2012, 01:17 PM   #5
Rewards Points: 776
What are they?
TIA.
Sounds like a "stump the band" question. I think OP thinks he knows the answer and is testing the rest of us.....
curiousB is offline   Reply With Quote
Old 06-04-2012, 02:28 PM   #6
Nah, I'm hoping there is a general answer to this general question.
I'm sure this request/problem will pop up again so it'd be good if I could run through the legitimate options.
I'm also curious about what makes it wrong to use illegitimate options that actually work and are reasonably safe, but that is kind of an overly broad question.
If tandems are allowed, what kind of wording would I look for on the label? Are there clearcut conditions where they are not allowed?
http://electrical.about.com/od/panel...embreakers.htm
Seems I need some practice reading panel labels.
Assuming I can find an appropriate two-wire-to-one-wire fitting and a branch circuit that is chronically underloaded, why can't I just put two wires into the same breaker?
So far, so good. . .
Service Cable from Meter to Load Center monkeystomach Electrical 13 04-26-2012 09:19 AM
Connecting Conduit to Outdoor Load Center a_lost_shadow Electrical 2 01-21-2012 11:07 AM
Looking for "Wrongs" in my Siemens load center Minus08 Electrical 31 01-11-2012 11:47 PM
Load Center Generater Interlock in Cook County, IL shilohqdog Electrical 2 02-20-2011 04:57 PM
Load Center Replacement Question EmilG Electrical 10 09-29-2010 01:11 PM
