Load Calculations - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 06:20 PM   #1
Rewards Points: 135
Load calculations
When doing load calcs for a 20A circuit how close to 20A is allowed by code?
Am I using the formula P=EI?
This circuit is for kitchen/dining area lighting which will include approx. 11 recessed cans, ceiling fan w/4 lights, fixture over island and under counter lighting along approx 18' of counter.
elmaur is offline   Reply With Quote
Old 05-28-2012, 06:23 PM   #2
Licensed electrician
Rewards Points: 1,464
Residential lighting is not considered a continuous load you you can go all the way to 20 amps. Many would limit themselves to 80% or 16 amps.
Remember to calculate the maximum wattage of the recessed, not just the bulb wattage used.
Code05 (05-28-2012)
Old 05-28-2012, 06:33 PM   #3
Rewards Points: 135
I am approximating at this time a 2KW load as the absolute max. Am I using 110V as my reference? And if so I am at 18A. Would you leave it on the one 20A circuit?
Old 05-28-2012, 06:39 PM   #4
For calculations the correct voltage is 120, not 110.
At 17 amps I would leave it as one circuit.
elmaur (05-28-2012)
Old 05-28-2012, 06:47 PM   #5
Rewards Points: 135
I am surprised to learn 120 is for calculations. I have not measured in this house but I seem to remember seeing 110v or maybe even a bit less in a previous residence so I assumed 110v would be the reference.
Old 05-28-2012, 06:57 PM   #6
Code05's Avatar
Rewards Points: 1,104
I can cite the NEC section if you want, but Jim is correct.
Here:
220.5 Calculations.
(A) Voltages. Unless other voltages are specified, for purposes
of calculating branch-circuit and feeder loads, nominal
system voltages of 120, 120/240, 208Y/120, 240, 347,
480Y/277, 480, 600Y/347, and 600 volts shall be used.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
elmaur (05-28-2012)
Old 05-28-2012, 07:01 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
110, 115, and 117 are all previous numbers used, we now use 120 as a nominal number in the US.
The Following User Says Thank You to stickboy1375 For This Useful Post:
elmaur (05-28-2012)
Old 05-28-2012, 07:03 PM   #8
E2 Electrician
2400 watts per 20 amp circuit is acceptable....
Old 05-28-2012, 07:08 PM   #9
Code05's Avatar
Yes, but usually I do my calcs in VA, I do not always know my PF.
Old 05-28-2012, 07:13 PM   #10
E2 Electrician
lol... good idea.
Old 05-28-2012, 07:21 PM   #11
Rewards Points: 135
What is PF?
Old 05-28-2012, 07:28 PM   #12
Code05's Avatar
What is PF?
Power Factor, forget about it, it is an electrician thing.
I was just teasing Stickboy.
Old 05-28-2012, 07:28 PM   #13
E2 Electrician
What is PF?
Power Factor
Old 05-28-2012, 07:31 PM   #14
Code05's Avatar
Actually, you should know one thing: if anyone tries to sell you a device saying that it will correct yours-run like hell, it is a scam.
Old 05-28-2012, 07:43 PM   #15
Rewards Points: 135
Actually it's an electrical theory thing. I studied electrical/electronics technology in school many years ago. I do know there is a difference in calculating DC and AC values. I need to brush up on it.
BTW P=EI is the same as P= VA
Load Calculation Fee - HVAC Contractors Please DIYerIT HVAC 2 07-30-2011 04:39 PM
Want to open up a load bearing wall - I need advice on a header to carry the load graysqwrl Building & Construction 4 07-16-2011 08:16 AM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 10:09 AM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 11:49 AM
More Accurate Load Calculation zootjeff HVAC 9 12-14-2009 12:06 AM
