Live Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 07:12 AM   #1
Live wire?
Hey all,
When demoing floor i discovered a live wire under floor joist / however it is caped / taped and not interfering with anything. The problem is that trying to find the source to disconect is difficult / it's a condo with three boxes and a jungle of wires that it could be tied too. I tried but had no luck.
I know it's not great but do you think i would be ok to look the other way on this and continue working?
Casey_Oakland is offline   Reply With Quote
Old 02-22-2009, 07:32 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
If you cant trace it back to its source then I would a least put it in a splice box with cover. you didn't say if it was.
but the thing that would bother me is code says all slices and boxes must be accessible. you might want to get an electrician in there to kill that wire. BOB.
Old 02-22-2009, 07:37 AM   #3
yeah.. not in a box but, i would need to tear into the floor more in order to get to it and make that happen.
Old 02-22-2009, 07:42 AM   #4
Remodeling Contractor
Turn breakers off one at a time until the power is not live on this wire. Then check what other devices are also off. Start with the closest one and check if any of these spliced wires are connected to this one. Disconnect at that junction.
Old 02-22-2009, 07:57 AM   #5
This will effect others in the condo as I believe it is tied to another box.
Old 02-22-2009, 08:43 AM   #6
Rewards Points: 502
That inconvenience is worth it in the long run when trying to remove a potential fire hazard and solve a code violation.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-22-2009, 10:22 AM   #7
If it's a single dead ended cable and it is capped and taped properly, leave it. Not code but not dangerous.
If it is a splice, do not leave it......please do not leave it.
I am begging you.....please.
220/221 is offline   Reply With Quote
Old 02-22-2009, 10:42 AM   #8
It is a single line but i am curious...
If it was a splice why is that more of an issue?
Thanks.
Old 02-22-2009, 11:21 AM   #9
buletbob's Avatar
Splices could go bad! and if that does happen there would be one hell of a time trying to locate it. BOB.
plus its against code. all splice boxes must be accessible.
Old 02-22-2009, 11:59 AM   #10
so... ummm..
Guess what i found now!!
yep.. (OLD) buried box / again caped taped and covered but unfortunately spliced and not accessible. I turned off my power with no effect so it appears to be apart of the 2nd floor apartment under me. Not sure what to do as it's not even my wiring and I can not build accesibility to it in my floors!? I dont think the guy on the 2nd floor will be willing to tear out he's old wiring.
Old 02-22-2009, 01:53 PM   #11
He needs to install a box & put a cover on to make the splice accessible
Or replace the wiring
Is your work being inspected?
Or are you just redoing the floor - no electrical?
I wouldn't leave it - that's a possible problem down the road
Old 02-22-2009, 01:57 PM   #12
the splice is in a box / caped / taped and covered / just not accessible.
No inspector / just the floors here.
Is this a judgment call? As far as i can tell this has been like this for a very long time.
Old 02-22-2009, 02:03 PM   #13
Rewards Points: 2,350
If it is the guy downstairs' wiring, I'd let him know what you found, then I'd lay my floor and let him worry about it.
Old 02-22-2009, 02:08 PM   #14
I'd let him know
Maybe measure where it is so it can be located easily
I'm not sure on code on this since it isn't your wiring
If I lived downstairs I'd want to fix it
But probably many people would not want to fix something that isn't "broken"
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Live wire hanging from basement ceiling yummy mummy Electrical 30 12-04-2007 10:43 AM
What color wire is live? poggs Electrical 2 03-08-2005 05:58 PM
