'Live' Earth Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2008, 02:39 PM   #1
'Live' earth problem
I am in the process of wiring in a new oven to replace our 20 yr old one which died last week and noticed that the earth on the cooker control switch is giving a faint glow on the electrical screwdriver. I also noticed that live-out on the switch lights up the neon when the switch is off (though slightly less bright than the glow from earth). What's going on?
Jard
Jardov is offline   Reply With Quote
Old 04-11-2008, 02:55 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I would state in your profile, or at least your posts, that you are from the UK. Not everyone knows the terminology, such as "earth" and "cooker".
Speedy Petey is online now   Reply With Quote
Old 04-19-2008, 07:02 PM   #3
Electrical Technician
You may have a slight leakage on the switch terminals especially if its an old cooker control,they get carboned up and do conduct slightly.
I would change the cooker control and it should solve it.
ALSO
I have never liked the idea of people using a neon screwdriver or indicator , especially the type where you become part of the circuit under test.
It often does happen that the resistor ( a tiny piece of carbon or similar substance ) is the onlything stopping you taking the whole current,which depending on where you are in relation to the tranformer could end up with +20kA at the terminals or the end of your inicator.
Chris
chrisb271 is offline   Reply With Quote
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 04:55 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
Polish flat - No earth! Sosh Electrical 3 07-10-2007 12:49 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
3 phase anyone? Tomkah Electrical 3 01-05-2007 06:18 PM
