Live Charge In Water Stream? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 12:03 AM   #1
sparky89
live charge in water stream?
Hello, what could be the cause of the kitchen sink faucet stream feeling a slight tingling sensation when the garbage disposal is running?
Can't be good, I know!
Possibly a grounding issue? 200 Amp service w/ two subpanels.
House is about 25 years old.
Thanks for any help how to start troubleshooting.
sparky89 is offline   Reply With Quote
Old 04-21-2012, 12:18 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Use a meter to check it and not your hands.
Turn off breakers until the voltage goes away, then check that circuit.
Old 04-21-2012, 12:22 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
You have an appliance that is leaking some current into the earth line !
Turn things off one by one till you find it !
Then double check all eathing associatted with it !
right back to the panel if nessisary!
dmxtothemax is offline   Reply With Quote
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
