Little Square Machine Screw Nuts - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 05:19 PM   #1
Rewards Points: 270
Little square machine screw nuts
I did the wiring in my kitchen and tossed out the little square things. Now we just had 1/4" thick tiles put in and am realizing those little square things were probably to keep the outlets sticking out... am I right and is there any way to purchase these things separately????
pcampbell is offline   Reply With Quote
Old 10-23-2008, 05:35 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I cannot picture what you are talking about.
Old 10-23-2008, 05:50 PM   #3
Registered User
Termite's Avatar
He's talking about the little 1/4" squares of plastic that retain the mounting screws in receptacles and switches.
I've never seen them for sale by themselves. Get a plastic package of some sort or a plastic sour cream or butter tub and make some replacements out of it with a utility knife.
They aren't really for making the receptacles and switches stick out, they're for retaining the screws in the holes to make it easier to mount the devices in the electric boxes. If your boxes were set too deep and aren't pretty close to flush with the face of the wall then you'll need to use box extensions anyway, so working to replace the little square doohickeys might be fairly unnecessary. Your switches and receptacles must make solid contact with the face of the box or they'll only be supported by the cover plate and will wiggle around.
Old 10-23-2008, 06:03 PM   #4
joed's Avatar
Rewards Points: 13,752
How far out do you need? Look for box extenders.
Old 10-23-2008, 06:25 PM   #5
Rewards Points: 270
Hmmm OK. I guess that isn't what they are for.
How short can box extenders be? I only need 1/4".
If I don't use something behind there, then when I screw in the outlets and plug something in, they will recess back further than the wall plate. I.e. theres nothing for them to push against. The ears are not catching on the tiles.
Old 10-23-2008, 06:48 PM   #6
Rewards Points: 1,772
I know HD has them in different thicknesses. They're plastic and cheap and a great idea that I wish I had thought of.
bob22 is offline   Reply With Quote
Old 10-23-2008, 07:02 PM   #7
electrical contractor
Rewards Points: 150
Gardner Bender makes a spacer that will do what you need. I have gotten them from the electrical dept. at Home Depot. They come in a package of 20 or 25 for 5 or 6 dollars. They are about 3 inches long and are segmented so you can fold them over on themselves to get more thickness. Should be easy to see as they are fluorescent green. I keep them on my truck now do not think I could trim out a house without them. What did we use before we had these things??
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 10-23-2008, 08:11 PM   #8
joed's Avatar
If the gap 1/4" then you need box extenders. I think 1/8" is the max gap under code.
Old 10-24-2008, 07:41 AM   #9
Rewards Points: 270
thanks i'll go get those.
Old 10-24-2008, 11:47 AM   #10
DIY'r
ScottR's Avatar
I thought it was up to 1/4" allowed by code?
ScottR is offline   Reply With Quote
Old 10-24-2008, 12:49 PM   #11
Rewards Points: 266
Up to a 1/4" in a noncombustible wall surface. If the box is installed in a combustible wall it needs to be flush. Since the wall surface is tile, up to a 1/4" is fine.
junkcollector is offline   Reply With Quote
Old 10-24-2008, 01:54 PM   #12
Check this out
They make them in plastic too.
hpp58 is offline   Reply With Quote
Old 10-24-2008, 03:50 PM   #13
Registered User
Termite's Avatar
Nifty...Haven't ever seen a metal one like that. The plastic ones are sure gaining in popularity. Allied Molded has a pretty nice one that I'm seeing occasionally.
Old 10-24-2008, 06:25 PM   #14
jbfan's Avatar
Rewards Points: 650
Is that the one with the screws inside and slides on a rail?
I just received my ECM and saw them advertised.
Problems With Atlas Shingles Roof Consultant Roofing/Siding 116 06-04-2016 04:49 AM
Poor Attic Ventilation Mechanically Challenged Roofing/Siding 15 10-23-2008 09:05 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
roof venting via the soffit darren Roofing/Siding 8 04-13-2008 09:29 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
