Old 03-03-2007, 04:03 PM   #1
Little Question Please Help : )
I recently purchased a 2' 2 light fluorescent fixture and I was wondering if I could make a power cable that I can plug into a wall by connecting a replacement power cable to the two wires coming out of the balast. Thanks
Justin860 is offline   Reply With Quote
Old 03-03-2007, 04:18 PM   #2
you can buy whips that have a plug on one end and open wires on the other.
gooch is offline   Reply With Quote
Old 03-03-2007, 04:23 PM   #3
Where can I buy that? I only have a lowes, walmart, and radioshack around here. Also, how would I put it together, regular twist wire connectors?
Old 03-03-2007, 11:49 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
You can get them at lowes. What you want is called a power cord. It will have a nema 5-15 male plug on the end and black, white and green wires that can be connected to the ballast wires with wire nuts. You will also need a clamp for the cord to secure it to the light fixture knockout hole. Do a search at lowes.com. It should show a picture of one.
Stubbie
Old 03-04-2007, 12:38 AM   #5
thanks a bunch, i already went to the store today and got a 14 ga extension cord and took off the female end and then stripped the wires to attatch to the ballast wires, only problem is that the middle wire is green and the other two arent colored : (
Old 03-04-2007, 12:40 AM   #6
also where do i put the ground screw????
Old 03-04-2007, 06:53 AM   #7
Take a tester and make sure that the green wire shows condunity to the round prong (or pin shape) of the cord cap that is by itself at the bottom. The ground pin should be the green wire and connect to a ground screw on the light fixture.
The two blade prongs are hot and neutral. If you look at the face of a recepticle the hot is the smaller one. Hold your cord cap up and visualize which prong on your cord cap that would be and ring it out to the other end and hook it up to the black from the ballast.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-04-2007, 09:13 AM   #8
I have a green screw and a ring that goes with it but where do i put it on the light fixture???
Old 03-04-2007, 12:05 PM   #9
Electrical Contractor
See the answer I gave to your other post!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 03-04-2007, 06:26 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
I did not realize this thread had wandered into the grounding question.
JW is right. There was no reason to start the other thread.
In any case I see both questions have been answered.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Outdoor Slate Question (with pictures) kabbak Flooring 2 07-05-2006 04:02 PM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 09:04 AM
