A Little Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 02:08 PM   #1
a little problem
i have a circuit which has a wall light and 4 outlets there is power everywhere in the circuit but none of the outlets or the wall light work any clue what it could be?
jheinrich is offline   Reply With Quote
Old 11-23-2008, 03:01 PM   #2
dSilanskas's Avatar
Take down the lights and check the wires make sure there is no loose connections
dSilanskas is offline   Reply With Quote
Old 11-23-2008, 03:33 PM   #3
Check the lights and switch first for loose connections...have you been doing some work with saws, drills, etc?
rgsgww is offline   Reply With Quote
Old 11-23-2008, 04:21 PM   #4
Electrician
How have you determined there is power everywhere?
My best guess would be that you have lost the neutral. Check all of the connections in the circuit and also check for voltage with a meter. Measure between hot and neutral, and then between hot and ground. If you have power between hot and ground but not between hot and neutral, then you have a bad neutral connection somewhere.
EBFD6 is offline   Reply With Quote
Old 11-24-2008, 11:30 AM   #5
there is power between hot and neutral if i check it at the terminals on the back reads at 120 is there any tests i can do with the multimeter to narrow things down? thank you for your help
Old 11-24-2008, 02:27 PM   #6
Are you sure you checked ALL connections?
Check for loose connections, Ive seen issues with low voltage ONLY when current is applied.
Do you have aluminum wire? (silvery, soft wire)
Old 11-24-2008, 05:43 PM   #7
losing the neutral
With 1200w into the house and a neutral connection of 3 ohms instead of zero, you can have 96v on one side of the house and 144v on the other side. This bad neutral connection would have 24v across it.
Old 11-25-2008, 11:44 AM   #8
no its copper wire didnt check all connections its probably in the light because thats where the recepticles are wired from
Old 11-25-2008, 01:59 PM   #9
Rewards Points: 894
By any chance is one of the receptacles on the circuit a GFCI? If it is, I'll bet the GFCI has tripped, cutting power to it and all downstream.
Ultrarunner2017 is offline   Reply With Quote
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
