A Little Lighting Help Please ... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 10:19 AM   #1
Rewards Points: 189
A little lighting help please ...
I pulled a light out of a closet to replace it and now cant remember what wires go where when hooking it back up ...
Here is what I have ...
1. A lightswitch with a black and red wire attached to it ...
the black comes from a group of blacks and the red goes to where the light will be installed ...the white from this lines is grouped w other whites in the box ...
At the light location I have a 14/2 and 14/3 romex .. the 14/3 has is the switch leg w the red from the light switch. ..
My question is how do I hook the new light up? I am assuming the red wire from the switch is used, the whites all stay seperate and tie together, and the blacks are also run to the fixture?
Thanks for any info.
beachfront71 is offline   Reply With Quote
Old 07-01-2011, 10:31 AM   #2
Rewards Points: 6,652
You have what is called a "Switch leg" Power goes into the box that the light sits in, and switched from the light switch. White on the fixture goes to the black on the switch, Black goes to the Red on the switch. This is why you either write down on paper what goes where before unhooking, or leave connected, until you get the new fixture. Never unhook until you make notes of how it was hooked up.
Old 07-01-2011, 10:55 AM   #3
Rewards Points: 189
thanks greg!
I took a picture of it then had to replce the iphone but I totally agree ..
I am using this to add 4" cans .. once I get the first one hooked up and working is it just a matter of adding another romex run to the second can and connecting the same wires?
Again, thanks,
Old 07-01-2011, 11:08 AM   #4
I ask the impossible!
Rewards Points: 704
Hang on though, he said the switch has black and red connected... What he has sounds more like this diagram
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 07-01-2011, 11:10 AM   #5
the Musigician
DangerMouse's Avatar
Originally Posted by beachfront71 View Post
I took a picture of it then had to replace the iphone
I highly advise anyone taking apart a switch or whatever to take a picture for reference. In your case, if it happens again, email the picture to yourself.
DM
Old 07-01-2011, 04:03 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by gregzoll View Post
... White on the fixture goes to the black on the switch, black goes to the red on the switch...
Kyle
Old 07-01-2011, 04:15 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
The 14/3 that runs from the light to the switch box…is that black tied to the other blacks in the switch box? And has a jumper wire to the switch? You already said the red was tied to the switch, and the white tied to the other whites.
If this is the case…
At the light box…
Black to black
White to white and to white of light
Red to black of light
Kyle
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
