-   -   A little lighting help please ... (http://www.diychatroom.com/f18/little-lighting-help-please-109364/)
beachfront71 07-01-2011 10:19 AM
I pulled a light out of a closet to replace it and now cant remember what wires go where when hooking it back up ...
Here is what I have ...
1. A lightswitch with a black and red wire attached to it ...
the black comes from a group of blacks and the red goes to where the light will be installed ...the white from this lines is grouped w other whites in the box ...
At the light location I have a 14/2 and 14/3 romex .. the 14/3 has is the switch leg w the red from the light switch. ..
My question is how do I hook the new light up? I am assuming the red wire from the switch is used, the whites all stay seperate and tie together, and the blacks are also run to the fixture?
Thanks for any info.
gregzoll 07-01-2011 10:31 AM
You have what is called a "Switch leg" Power goes into the box that the light sits in, and switched from the light switch. White on the fixture goes to the black on the switch, Black goes to the Red on the switch. This is why you either write down on paper what goes where before unhooking, or leave connected, until you get the new fixture. Never unhook until you make notes of how it was hooked up.
beachfront71 07-01-2011 10:55 AM
thanks greg!
I took a picture of it then had to replce the iphone but I totally agree ..
I am using this to add 4" cans .. once I get the first one hooked up and working is it just a matter of adding another romex run to the second can and connecting the same wires?
Again, thanks,
WillK 07-01-2011 11:08 AM
1 Attachment(s)
Hang on though, he said the switch has black and red connected... What he has sounds more like this diagram
DangerMouse 07-01-2011 11:10 AM
Originally Posted by beachfront71 (Post 677903)
I took a picture of it then had to replace the iphone
I highly advise anyone taking apart a switch or whatever to take a picture for reference. In your case, if it happens again, email the picture to yourself. :)
DM
SD515 07-01-2011 04:03 PM
Originally Posted by gregzoll (Post 677894)
... White on the fixture goes to the black on the switch, black goes to the red on the switch...
SD515 07-01-2011 04:15 PM
The 14/3 that runs from the light to the switch box…is that black tied to the other blacks in the switch box? And has a jumper wire to the switch? You already said the red was tied to the switch, and the white tied to the other whites.
If this is the case…
At the light box…
Black to black
White to white and to white of light
Red to black of light
