Old 08-05-2012, 07:44 PM   #1
List of questions
I know it's best to group questions alike into there own threads, but I did not want to have to many active threads at one time so I hope you'll don't mind.
I'm rewiring a 1950's ranch so I'm stuck with most of the new codes and I’m not all the way up to speed with them yet.
The first circuit to the bath room will have 2 GFCI outlets and the light.
The second bathroom circuit with be for a fan, light, and heat combo.
Will the bathroom circuits need AFCI breakers?
The kitchen will have 4 GFCI counter outlets each with it's own circuit.
The fridge, dishwasher, and microwave / hod will have there own circuits.
There will be another circuit with a wall outlet, and a light / fan combo.
Will I need 8 AFCI breakers for the kitchen or just 1 for the outlet and lights?
The dishwasher is next to the sink, but no GFCI?
I was planning on the hall light and smoke detectors to be on 1 circuit.
Main level placement; 1 out side the 2 bed rooms in the hall and one in the living room near the kitchen.
The basement has a utility room and I was planning 2.
I'm going to use 12/3 with them for the interconnect.
Am I missing anything and dose it sound right?
I'm thinking about putting a 100 amp sub panel in the utility room to save on the amount of home runs going to the main panel and I think would cut down on wire cost. The kitchen is right above the utility room so I was thinking running those to the sub pannel.
I would like to do a load calculation, but not sure how to do them and I’m just guessing at the wattage.
hot water heater (tank) 4,500
range 3,000
2 ton HVAC compressor 2,500
air handler with back up electric heat 10,000 (wild guess)
clothes dryer 5,000
clothes washer 1,000
dishwasher 1,200
fridge 700
microwave / hood 1,200
4 counter outlets 3,000 watts
With out derating anything and not knowing how to do this I came out to 135 amps per phase.
How do I properly do the load calculation?
1950home is offline   Reply With Quote
Old 08-05-2012, 08:02 PM   #2
Licensed Electrician
k_buz's Avatar
List of questions
Will the bathroom circuits need AFCI breakers? No
Will I need 8 AFCI breakers for the kitchen or just 1 for the outlet and lights? You will need one AFCI for the wall outlet and light/fan
The dishwasher is next to the sink, but no GFCI? If it is a built in dishwasher, no
You can use 14-3 and put it on a 15A breaker. I am pretty sure they have to be on an AFCI breaker. You need a smoke/CO detector on each floor. You need a smoke inside each bedroom and outside the group of bedrooms (I think its 6' from the doors). The basement only needs one if there are no bedrooms.
range 3,000
clothes dryer 5,000
dishwasher 1,200
fridge 700
That is a large subpanel, what is your current electrical service rated at?
Answers in red
Location...Location...Location
Old 08-05-2012, 08:11 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
List of questions
Just want to point out, in the first question you mentioned two GFI outlets om one circuit.
You cannot use two GFI recepticles, but feed the 2nd outlet off the first GFI for protection.
I hope this is what you meant
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-05-2012, 08:31 PM   #4
k_buz's Avatar
List of questions
Why not?
The Following User Says Thank You to k_buz For This Useful Post:
brric (08-05-2012)
Old 08-05-2012, 08:35 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
List of questions
Maybe i didnt explain right. Im saying two GFI in series on the same circuit will compete with each other.
Far as i know you cannot run GFI back to back. Please correct me if im wrong.
Old 08-05-2012, 08:39 PM   #6
k_buz's Avatar
List of questions
You can, but if you load one GFI off another GFI it can become confusing on which recept is causing the problem should one arise. You can, however, pig tail the hots at first GFI and run straight power to the second GFI.
I would prefer to do all my GFI's this way, but customer/bosses don't like to pay the extra $$ for the device.
MisterZ (08-05-2012)
Old 08-05-2012, 08:44 PM   #7
"So I Re-Wired It"
MisterZ's Avatar
List of questions
Nice, in your setup both gfi's will trip individually.
I was just saying its a common mistake to come off the accesory screws to feed another gfi
Old 08-05-2012, 09:02 PM   #8
Electrical Contractor
List of questions
That is a misconception, as they will work, but will be confusing to find which gfci tripped
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (08-06-2012)
Old 08-05-2012, 10:15 PM   #9
List of questions
Thank you k_buz
You saved me a lot of time searching and headaches down the road.
Great to know with the smoke alarms, thank you.
In 1997 the service was up dated to 200 amp Cutler Hammer panel. The rest of the service was also done. My house is about 925 square feet with unfinished basement.
When you type it all out it sound huge. My parents house was also all electrical, had a well, sump pump, and was fine with a 100 amp service until he got to many toys.
Depending on how you wire 2 GFCI outlets on the same circuit your in for some fun when one trips.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 07:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-25-2010 12:53 AM
A few roof questions before I begin... chrisexv6 Roofing 6 05-02-2010 07:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
