Liquid Electrical Tape? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2009, 02:12 AM   #1
WaldenL's Avatar
Rewards Points: 268
I was in Lowes this evening and saw a can of Liquid Electrical Tape. Anyone used this? Do I just paint it on the connection I'd normally wrap with tape? Good? Bad? Seems like a great idea.
WaldenL is offline   Reply With Quote
Old 10-21-2009, 08:28 AM   #2
Licensed electrician
Rewards Points: 1,266
I have used the 3M liquid repair to fix nicks in UF cables that had been damaged. No problems that I am aware of.
Old 10-21-2009, 08:51 AM   #3
Rewards Points: 6,652
We used it to make waterproof connections in the Navy. First wrap was always Rubber Tape, then Electrical, then coat with the 3M Liquid Tape.
Old 10-21-2009, 10:07 AM   #4
Is it suitable for a buried cable?
Old 10-21-2009, 11:46 AM   #5
Rewards Points: 1,910
Not sure about the code requirements and all but I did use it to repair a nick on a buried cable feeding my metal building about 13 years ago. Nicked it digging a necessary trench with a backhoe. (I had the power off because I knew I was very close to the wires).
I cleaned the nick, put layer after layer of the liquid tape on (letting it dry between layers) until it built up fairly thick then wrapped it with the best electrical tape I could get. I haven't observed any problems with the repair.
Old 10-21-2009, 11:51 AM   #6
Rewards Points: 80
The only place I have seen it used was for wet location terminations. Like after the VC, rubber and regular tape, they would put a coat of the 3m on at the end. I have never personally had any faith in it. It's been around for many many years if we are talking about the same product.
Old 11-17-2010, 12:31 PM   #7
Seems to be highly regarded stuff
These UK ham radio hobbyists swear by it:
http://www.sotabeams.co.uk/liquidtape.htm
mguerreiro is offline   Reply With Quote
Old 11-17-2010, 08:37 PM   #8
I always used it on my 5th wheel RV brake wiring! Never ever failed me!
I wrapped the splice with electrical tape and then painted it two times with the liquid tape.
On my needle nose pliers, the insulated grip broke off at the tip. I wrapped it with tape and painted it up and its been good for more than 5 years.
Old 11-17-2010, 09:24 PM   #9
Rewards Points: 150
Liqid vinyl is cool. Tape traps moisture and rots wires, it never dries out. Good for damage wires. I use in heavy equipment. I dont like cutting wire because now they are two wires.
ianc435 is offline   Reply With Quote
Old 11-18-2010, 08:36 AM   #10
Would this be any good for split bolt connectors?
itin1200 is offline   Reply With Quote
Old 11-18-2010, 10:19 AM   #11
At my last employer, I did a lot of parking lot light maintenance.
The lights were fed by direct buried wire, with the light standards tapped off the parallel feed.
We used Burndy Split lugs for these taps. At the time, rubber tape was wrapped over all conducting surfaces, followed by a covering of cotton, friction tape. This tape was in turn covered with 3M Scotch Coat.
I would be surrprised if Scotch Coat and Liquid Tape are not one and the same.
When 3M came out with their splice kits, we switched over to these. These kits have a clear plastic case and are filled with an epoxy filler that seals out the moisture.
No problem with varmints chewing on these!
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 07:56 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
