Line Voltage Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 05:12 PM   #1
Line voltage thermostat
Greetings to all, I'm hooking up a line voltage thermostat, cool only in my camper. My ? Is, does it make a difference which way you would hook the wires up? One is red and one is black , this is just a switch I would not think it makes a difference
Barry2080 is offline   Reply With Quote
Old 05-29-2013, 07:37 PM   #2
Rewards Points: 1,548
For a single pole switch (just two wires) it does not make any difference.
You have to be careful with a 2 pole switch (4 wires), intended for 240 volt circuits. If you make a mistake you could short out and burn out the switch (connect both hot supply wires to the two wires going to one switch pole). Except for this, it also does not make any difference.
Check the switch instructions.
Old 05-29-2013, 09:07 PM   #3
biggles's Avatar
if it is for a 115V unit break the hot/black at the stat so you read 115V to ground but not out the other side of that black to the unit to ground.....if 230V either won't matter just realize one side of the unit is hot in the off position at all times
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Line Volt Thermostat issue ctct000 Electrical 4 02-05-2011 09:06 AM
Line voltage 4x4 post light Joe F Electrical 2 04-26-2010 11:50 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage thermostat wiring dirtpig538 General DIY Discussions 2 02-14-2009 12:48 PM
