Line Tester? NOT For Use With Outlet! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 12:57 PM   #1
Rewards Points: 150
Line Tester? NOT for use with outlet!
I have 5 wires in a wall that I am trying to move. I have positivetly identified 3 of the lines. The other two lines I am unsure of but have a SUSPESION. I have a light in the kitchen that does NOT have a wall switch. (has chain like in a ceiling fan) I want to shut off the breaker to THAT light and then test the line I suspect goes to that light. ( I KNOW THIS IS GOING TO SOUND REALLY REALLY REALLY CORNY!) I watched the show Holmes on Holmes and he always has one in his pocket. Just holds it up the wires he finds in the wall and it lights if it is live. I "WANT" to say it began with a K. Klein, Kirby, but I could be wrong.
Thanks AGAIN
Evil Scotsman is offline   Reply With Quote
Old 11-10-2010, 01:13 PM   #2
Sounds like you are talking a voltage detector. These are commonly available for a few dollars at home depot, lowes, menards, etc. They may even be available at walmart. Anyone who does electric work should have one.
try:
http://www.lowes.com/pd_169-72068-GT...ntity_sold%7C1
oberkc is offline   Reply With Quote
Old 11-10-2010, 01:18 PM   #3
joed's Avatar
Rewards Points: 13,750
Commonly called a non contact voltage detector.
Old 11-10-2010, 01:21 PM   #4
Rewards Points: 150
I found it THANK YOU
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 11-10-2010, 01:25 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
You can also use a standard volt meter just need to be careful you don't accidentally cross the wires or what not. but non contact tester is a good tool to have as well. I like to use it, then if it's negative, use the volt meter. just to be safe. There's always the two finger test too. j/k
Old 11-10-2010, 01:59 PM   #6
Rewards Points: 150
Thanks Two finger test is exactly what I don't want to do! LOL Not AFRAID persay of electricity, but lets just say it has my UTMOST RESPECT! Got bite once, don't want it to happen again!
Old 11-10-2010, 07:13 PM   #7
Rewards Points: 150
... if you're just REPLACING the light, ie the old one still works... then kill circuits one at a time until it gets dark :D
emolatur is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Installing a new in-line electrical outlet Nedly83 Electrical 5 09-01-2009 07:44 AM
Outlet wiring dilemma Mac McCloskey Electrical 8 08-17-2009 06:38 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
