In-line Splice , How To? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 04:57 PM   #1
In-line splice , how to?
I have an actuator that I want to install in my wall behind the sheetrock to conceal a small gun safe. The actuator runs off of a 12v dc adapter which i want to somehow hardwire into the existing romex wire that is there. I want all the connections to also be concealed behind the sheetrock. How would I properly connect this actuator to the existing wiring?
mike12345 is offline   Reply With Quote
Old 01-31-2011, 05:43 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,942
So you want the 12V adapter to be inside the wall, powered by the existing romex that happens to be running through the area? The only legit way to do this is to install a receptacle in a box inside the wall, with a removable access panel in the drywall so you can get to the receptacle and adapter. This may be a challenging installation, especially if you want to do it without removing much drywall. Is there an attic above this? It would probably be easier to install a receptacle in the attic to plug the 12V adapter into, then run the 12V wire down into the wall.
mpoulton is offline   Reply With Quote
Old 01-31-2011, 06:25 PM   #3
joed's Avatar
Rewards Points: 12,924
The only way to have the connections concealed behind drywall is to have a removable access panel. The panel can screwed on or look like anything else, but it has to be removable.
Old 01-31-2011, 06:30 PM   #4
Hmm I guess I would have to install te receptacle because there is no attic. But I would have to eliminate access to the wiring in order to keep it concealed
Old 01-31-2011, 06:36 PM   #5
joed's Avatar
It must be accessible. Removing the safe to access it might be considered accessible. What exactly are you trying to accomplish?
Old 02-10-2011, 05:53 PM   #6
Hey guys just thought you might want to take a look at the finished product. It ended up working out pretty good.
http://www.sendspace.com/file/nhprnn
Old 02-10-2011, 06:31 PM   #7
A 90MB movie?! How about a couple of simple photos instead?
Willis
williswires is offline   Reply With Quote
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 06:31 PM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 09:30 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
