Line And Phase Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 12:08 AM   #1
line and phase voltage
sir
i have seen on this site------------------------------------------------------------120/240 for houses: 120 is line to ground, 240 is line to line
so got the point from this point that we have three phase connection so
120 is phase voltage and 240 is line voltage
but line voltage is=squareroot of 3 *phase voltage and (240 is not equal to sqroot of 3*120)
please send the answer on --------- as soon as possible
Last edited by Gary in WA; 05-04-2012 at 01:08 AM. Reason: Removed link as per forum rules.
ashish walia is offline   Reply With Quote
Old 05-04-2012, 01:17 AM   #2
WOW. Thats quite a theory.
The first sentence is OK.
The rest is not.
Didn't come from here.
jammin06 is offline   Reply With Quote
Old 05-04-2012, 02:28 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 820
Originally Posted by ashish walia View Post
sir
Residential 240 is not 3 phase...it's single phase.....with a center tap neutral reference.
This picture might help illustrate how it works.
Old 05-04-2012, 06:52 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Ummmmmm......NOPE!
A) I don't answer forum posts privately. That is completely counter to what these forums are all about.
B) I don't do home work for other people.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (05-04-2012), user1007 (05-04-2012)
Old 05-04-2012, 07:44 AM   #5
Rewards Points: 1,418
sir
i have seen (snip) 120/240 for houses: 120 is line to ground, 240 is line to line
(snip)
If you indeed had two legs of a symmetric neutral (wye; star; etoile) 3 phase system as your service then hot to hot would measure about 208 volts.
Once in awhile, residences in (upper floors of?) a commercial building or in a primarily commercial district may have 120/208 volt service taken from 3 phase pole transformers. In general, 120/240 rated and 240 volt only rated equipment may not be connected to 120/208 volt systems and vice versa. Some equipment is rated for both voltages.
A 120/240 volt 3 phase system (it's always 3 phase delta) provides 120/240 volt single phase power per the diagram above and a third hot wire is for 240 volt only 3 phase equipment such as machinery,
Even in a three phase system of any kind, if you take power from any two terminals (hot and hot, or hot and neutral) you will have a single phase source.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 05-04-2012, 08:53 AM   #6
I=E/R
a7ecorsair's Avatar
sir
Why do you ask and where do you live?
a7ecorsair is offline   Reply With Quote
Old 05-04-2012, 08:56 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Old 05-04-2012, 07:26 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,098
sir
If your hot to neutral is measured at 120v !
Then the voltage across two hots depends on two things !
If it originates from a split supply then it will be 240v !
But if it is a measur ment from two phases,
of a three phase supply,
then it will not be 240v! but more like 220v,
Because the phase difference in a three phase system
would be only 120 degrees,
Where as in a split supply it would be 180 degrees.
If you are tring to understand electrical systems,
Then you must understand the difference between
split systems and three phase systems !
dmxtothemax is offline   Reply With Quote
Old 05-04-2012, 09:28 PM   #9
I=E/R
a7ecorsair's Avatar
Originally Posted by k_buz View Post
My take too.
Opening with "sir" also points to this tread being started in a foreign country
Let's see how long before ashish has a follow-up post
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 05-04-2012, 09:32 PM   #10
I've got a fiver that says she never returns.
Old 05-04-2012, 09:51 PM   #11
Too Short? Cut it Again!
I will take the bet if you tell me if we are playing $5 with US dollars, Irish pound notes, or Euros. I need 3:1 at least though to bank the bet.
We in the US love our electrical system. The fact that a mean or wayward squirrel can take out entire sections of the country does not 1-2 or even 3 phase us at all?
My fave 3-phase equipment is mass transportation and I love the pigeons of Philadelphia most with no claws and just balancing on nubs.
I grew up with 3-phase when it supposedly kept giant saws and things working longer.
When the OP responds again I am going to use the money I won from you, at Target or something, to buy me a 3-phase meat grinder.
The Following User Says Thank You to user1007 For This Useful Post:
Speedy Petey (05-04-2012)
Running 220v Electronics on 120V Outlet? hellfire Electrical 42 01-14-2014 09:59 PM
making a 3phase house a single AzApache Electrical 7 12-09-2011 06:11 PM
confused about,208/240 lionking Electrical 10 10-26-2010 10:54 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
3 phase crazydog Electrical 10 08-20-2007 11:47 PM
