Old 01-05-2013, 12:20 PM   #1
Send a message via AIM to theatretch85
In-Line duct fan, how to wire properly...
Bought two of these Suncort In-Line duct fans to improve the air flow to two rooms. My question is, how are you supposed to wire these properly when they don't give you a junction box to house the connections in? There is a small plastic grommet where the three wires come out the side of the fan (certainly not big enough for a piece of romex to go through). The instructions seem to indicate just wiring a cord to the three wires with wire nuts.
theatretch85 is offline   Reply With Quote
Old 01-05-2013, 12:26 PM   #2
Are the ducts going to be close enough to just mount a 2 X 4 juntion box to a floor joist?
Old 01-05-2013, 12:27 PM   #3
No, they are on opposite ends of the house.
Old 01-05-2013, 12:54 PM   #4
A "Handy Husband"
rjniles's Avatar
From the Sun-court web site instructions:
"Your In-Line Duct Fan™ must be connected to a 110/120 Volt AC, 60Hz fuse or circuit breaker protected power source only in a manner approved by all applicable codes. Never connect your In-Line Duct Fan™ to a 240 Volt AC blower motor or other 240 Volt system. All electrical connections to this fan must be made in an approved junction box. This junction box must be permanently attached to the fan at the point where the motor wires exit the metal duct pipe. The junction box must be reliably mounted to prevent it from shifting or rotating. The junction box can be attached with 2 or more sheet metal screws, rivets or machine screws with a nut and lock washer. Power to the fan must be supplied following all applicable building and electrical codes."
http://www.suncourt.com/Inductor_Instructions.html
Coastal South Carolina
Old 01-05-2013, 01:01 PM   #5
Huh, I don't recall seeing that in the instructions that came with the fans. But that is exactly what I did (see the attachments)...
I also wired these to a junction box in the furnace room and used a RIBU1C relay to control them off the furnace fan wiring controls so they come on every time the fan is turned on (either automatically or manually at the thermostat).
http://www.functionaldevices.com/bui...p?model=RIBU1C
In-Line duct fan, how to wire properly...-imag1546.jpg   In-Line duct fan, how to wire properly...-imag1547.jpg   In-Line duct fan, how to wire properly...-imag1548.jpg   In-Line duct fan, how to wire properly...-imag1549.jpg
Old 01-05-2013, 02:58 PM   #6
If you find yourself less than pleased with the performance/noise levels of these axial fans, check out Fantech's FKD series: Fantech Centrifugal Blowers
kwilcox is offline   Reply With Quote
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 02:05 AM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
UVerse - Wire New Phone Line jhewitt Electrical 1 05-13-2010 05:29 PM
