Limiting Factor Of Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2014, 09:22 PM   #1
Rewards Points: 1,092
limiting factor of switch
What is the limiting factor of an electric switch? Amps, or watts? Situation: I can get a 250V, 20A toggle switch, STDP, that I'd like to use for a 12 or 24 V system. Am I limited to 20A even at 24V, or could the switch conceivably handle more amperage (ie, 200) at the reduced voltage? Thanks.
Old 04-02-2014, 09:30 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
THAT is actually a very good question.
A lot of factors go into a switch....AC vs DC, voltage and current.
For the most part....wattage is NOT a factor.
If you look at a switch, it should have specs for both AC and DC. In most cases, the DC current rating will be higher...most cases....but depends heavily on the contact material.
With DC, if your going to control a relay....you really need to make sure you put a diode across the relay coil to suppress the inductive kick. Otherwise, your switch has to absorb it...and that will shorten it's life quickly.
Additionally, voltage is also a big factor. A switch rated for 480 Vac is quite a bit different than one for 120 or 240Vac.
At the end of the day, it's pretty simple. Look at the spec's for the switch.
Edit....re-read your post......don't even think of trying to put 200a DC across that switch. Once again, it depends on what your load is. Inductive is worse than resistive. Case in point...the starter solenoid for your car starter (resistive and inductive).
May I suggest some reading.....Read up on Edison and Tesla.....history tends to put Edison on a pedestal....but in reality...it's a good thing Tesla came along.....
ddawg16 is online now   Reply With Quote
Old 04-02-2014, 09:56 PM   #3
thanks. i've been reading a bit, and the mechanics of the switch is also important. 12V switches tend to (or do) have wipers to make contact instead of a knife and ham setup (my analogy). i will definitely get a 12V switch of the proper amperage and bag the idea of using a 120V one.
Old 04-02-2014, 10:06 PM   #4
JOATMON
ddawg16's Avatar
You should see a 2000A draw out contactor.......
Old 04-03-2014, 01:14 AM   #5
I googled it; pretty impressive.
Old 04-03-2014, 05:43 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,372
The DC rating of an AC switch is only a small portion of its AC rating !
Do not use an AC switch on DC, especially if its a large load.
The internal arcing at switch off, will very quickly destroy the switch !
Best to use a switch designed for DC operation !
A switch designed for 20A AC will handle only 1 or 2A at DC!
FACTOID !
dmxtothemax is offline   Reply With Quote
Old 04-03-2014, 01:00 PM   #7
Thanks. I did not know that. FYI, however, I see a common mis-use of "factoid"; I learned this the hard way, from some students. Embarrassing....
"A factoid is a questionable or spurious (unverified, false, or fabricated) statement presented as a fact, but without supporting evidence."
Old 04-03-2014, 01:22 PM   #8
Oso954's Avatar
Rewards Points: 1,126
Most of the light switches you will find in a U.S. hardware store or big box, will have zero DC rating.
If there is a lot of DC in your area they might carry one or two snap switches with a DC rating.
Or, you can order something like
http://www.amazon.com/Leviton-12021-2W-Single-Pole-Industrial-Self-Grounding/dp/B003AUDC4I
Oso954 is offline   Reply With Quote
Old 04-03-2014, 05:38 PM   #9
Thanls !
Did not know that !
Old 04-03-2014, 05:56 PM   #10
you're welcome. i learned a lot from my high school students over the decades. man, there are some incredibly fast and well educated kids out there. one little twerp had to tell me that he missed ONE question out of 1600 on the SAT test; he wrote them to inform them that he thought they were wrong, and they probably were. cheers.
Old 04-03-2014, 11:16 PM   #11
The reason for the difference in ratings is !
At switch off, a dc circuit will arc across the switch contacts,
and because it is DC the arc will be maintained longer,
when compaired to an AC circuit, which will last only for the
remainder of the AC cycle, where it will die.
But no so with DC, it can remain for some time,
this tends to burn out the switch contacts real quick !
Special DC switchs are available which have a greater contact gap
with a quicker more snappy action.
Which is less likely to draw an arc !
Name:  dc switch.jpg
Here's a picture of old older style switch that was designed to be used
on AC or DC.
A large contact gap and a very snappy action.
The Following User Says Thank You to dmxtothemax For This Useful Post:
MTN REMODEL LLC (04-04-2014)
Old 04-04-2014, 12:22 AM   #12
ok. good to know.
Old 04-04-2014, 01:00 AM   #13
JOATMON
ddawg16's Avatar
Attachment 83445
on AC or DC.
To add to that.....one of the big factors is the type of load. What dmx is describing is typical of inductive loads, such as a relay. That is why one needs to put a diode (snubber) across the relay coil. Additionally, the contact material is quite a bit different for DC vs AC.
A classic example of a DC switch....the dist contacts on the old style dist.
Old 04-04-2014, 08:10 AM   #14
I am
http://www.amazon.com/Leviton-12021-.../dp/B003AUDC4I
I've wired three way switches for added interior lights in work van for three different trucks over the years....
never a problem.....
mmmmm... what's that I smell.. :- )
of course dc rated would be better though
UnclePhil is offline   Reply With Quote
Old 04-04-2014, 11:35 AM   #15
Oso954's Avatar
You can get 3way DC toggles and rockers for vehicles 12vdc at auto parts stores, marine stores, and you might even find them in a big box.
But the toggle looks like this.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
