Limit To How Many Wires Can Be Run Throught A Joist? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 10:30 AM   #1
Rewards Points: 27
Limit to how many wires can be run throught a joist?
Is there a limit to how many 12/2 wire can be run through a 3/4" hole drilled in my ceiling joists? Is 3 or 4 ok?
jailbird371 is offline   Reply With Quote
Old 08-03-2009, 01:26 PM   #2
as seen on tv
Rewards Points: 150
2 wires
qbert is offline   Reply With Quote
Old 08-03-2009, 01:48 PM   #3
300zx's Avatar
Post
Code does not directly address the number of cables that can pass thru a hole.Look at this thread Allowed to run more than one romex cable through a single hole in a joist?
300zx is offline   Reply With Quote
Old 08-03-2009, 02:50 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Up to FOUR 12/2 cables can be run without regard for ANY derating, if this is even an issue in the first place.
Speedy Petey is online now   Reply With Quote
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
floor joist issue drtbk4ever Building & Construction 4 03-22-2009 10:20 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
