Lightswitch No Longer Controls Receptacle After Changing It - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 11:44 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
When we first bought the house, there was a receptacle in the living room that was controllable from a lightswitch. I replaced all the receptacles in the room with newer looking flush style ones and now if I plug in a lamp in that receptacle for example it wont turn on via the switch.
Receptacle #1 (The one I broke the tab on) has 4 white wires + GND coming out of it... I can trace 1 white wire back to a red with a merret and another to a black... leaving the other 2 as neutral.
I've tried to follow this but not to much success. You need to start over and get a few things resolved as we go.
First the receptacle in box #1 cannot be a 1/2 switched receptacle as it appears to be power in on a black and power onward on the red. Why they used white pigtails I have no idea. But the big clue here is there are two more white wires connected to the receptacles silver screws. The choice for that receptacle is the entire receptacle is switched and any connected to its load side are also switched. Or it is just unswitched and power onward. Also the description of the wiring suggests conduit not cable.
Pictures please!!... of all switch boxes and receptacle boxes you messed with and make them clear enough to see the wiring so we are able to see the connections of wirenuts and receptacles.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-30-2009, 03:47 PM   #17
What if I switched the hot wires from the bottom brass to the top?
What if you stopped guessing and gave us the whole story up front
When you describe the wiring in the boxes, tell us how many cables and how many wires (2 or 3) in each cable (forget the bare grounds). Forget about any other pigtails etc. Just explain the stock wiring.
I shouldn't have to ask twenty questions but....does the 3 wire contine past the second recep?
All we can do is guess when we have limited info. I am still guessing that the 3 wire is getting backfed from another recep.
Think about the circuit as a path from point A to B to C........
220/221 is offline   Reply With Quote
Old 07-30-2009, 06:05 PM   #18
Fixed it... I decided **** it, I'll remove all the tabs on the brass side of all 4 receptacles... now both "Mystery Switches" control the bottom plugs of all 4 receptacles. Everything has power...
reason why I didn't bother to do this in the first place was
1- Only noticed 1 switched receptacle before changing them
2- thought that its kinda weird to have all 4 receptacles in a room setup as switched.
but anyways, all looks good. Thanks for the help... Between here and Google, I've learned alot.
earthad1 is offline   Reply With Quote
Old 07-30-2009, 07:02 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Ahhhh so this was a three way switch set up.....
Stubbie
Old 07-30-2009, 07:16 PM   #20
Breaking (or not) the tabs on switched recepts.
Originally Posted by 300zx View Post
You Are Correct!!
Not in all cases. When both loads are controlled by the switch! (No matter what)Don't drink and Drive!!!
spark plug is offline   Reply With Quote
Old 07-30-2009, 07:25 PM   #21
Guess so. Was not aware the 2 switches were connected my bad.
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 03:23 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 06:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 10:28 AM
