Old 09-21-2012, 02:13 PM   #1
lights won't turn on, circuit breaker is fine.
stair lights doesn't turn on, circuit breaker is fine. I even replaced a new breaker. I was messing around with the lights a week ago, and now it doesn't turn on. what could be the problem.
danio is offline   Reply With Quote
Old 09-21-2012, 02:48 PM   #2
Missouri Bound's Avatar
[quote=danio;1014574]I was messing around with the lights a week ago,[/quote]
This IS the problem. What were you doing? Is it a three way switch?
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
Code05 (09-21-2012), jbfan (09-21-2012)
Old 09-21-2012, 06:25 PM   #3
Have you checked for power available at the switch ?
Use a non contact tester !
dmxtothemax is offline   Reply With Quote
Old 09-21-2012, 06:37 PM   #4
You did change the light bulb to see if that was it right?
Go back and start checking all the connections.
Identifying Circuit Breaker for Partial Outage Circuit justplumducky Electrical 4 08-30-2012 11:44 AM
Added new breaker, no garage lights now. lum1nes Electrical 8 08-04-2012 08:50 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Circuit breaker popped and it is only connected to ceiling lights lisao Electrical 1 10-05-2010 09:34 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
