Lights Turn On. No Power To Wall Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2013, 04:36 PM   #1
Lights turn on. No power to wall outlets
The problem occurred sometime around Christmas, and I had plugged in a trickle charger and 2 30ft strings of icicle lights onto this one wall outlet. Now, I have no power from the two outlets in the garage or the one outside connected to the garage. The last time that I used the outlets, they all worked just fine. Now I have nothing.
The circuit breaker was not tripped, but the most unusual thing is I can still turn on the garage light. I turned off the breaker for the garage and the garage light turned off. I switched the breaker back on and the light came back on, and still have no power to any of the outlets. I would prefer to not have to call an electrician to pay money for a diagnosis and find out it was something that I can do.
Has anyone had this problem or have any idea what it could be?
Thanks for your help.
StarStryker11 is offline   Reply With Quote
Old 01-01-2013, 04:53 PM   #2
Licensed electrician
Rewards Points: 1,028
Have you checked to see if a GFI has tripped? These are common on receptacles in garages and for exterior receptacles.
Old 01-01-2013, 05:15 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,098
you dont say if the outlet that the trickle charger was plugged into still works ?
The light in the garage could be on a different circuit to the outlets.
So most likely is a tripped gfci !
or loose connecttion.
Do you know the wiring lay out ?
And where the non functioning oulets get there power from ?
Is it a dedicated breaker ?
Or is it tacked onto an existing circuit somewhere ?
dmxtothemax is offline   Reply With Quote
Old 01-01-2013, 05:16 PM   #4
..... Your a freaking genius and I am an idiot. THANK YOU!!! That was it. It looks like that all my outlets are connected. I have one GFI outlet in the garage and of course it has to be the one outlet that I'm never around and never use.
Old 01-01-2013, 05:25 PM   #5
All donations to the genius fund graciously accepted.
Tags
circuit , outlet , power , tripped
Safe to 'insert' a couple lights inline with 3 outlets? machouinard Electrical 21 02-16-2012 06:51 AM
Turn tub wall into shower wall Muttface Building & Construction 0 08-02-2011 03:47 PM
All the lights and Outlets on one Breaker? jonathan03 Electrical 7 03-15-2010 01:30 PM
Power to outlets but not enough? batesrt Electrical 5 02-04-2008 10:12 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
