-   -   Lights turn on. No power to wall outlets (http://www.diychatroom.com/f18/lights-turn-no-power-wall-outlets-167952/)
StarStryker11 01-01-2013 04:36 PM
The problem occurred sometime around Christmas, and I had plugged in a trickle charger and 2 30ft strings of icicle lights onto this one wall outlet. Now, I have no power from the two outlets in the garage or the one outside connected to the garage. The last time that I used the outlets, they all worked just fine. Now I have nothing.
The circuit breaker was not tripped, but the most unusual thing is I can still turn on the garage light. I turned off the breaker for the garage and the garage light turned off. I switched the breaker back on and the light came back on, and still have no power to any of the outlets. I would prefer to not have to call an electrician to pay money for a diagnosis and find out it was something that I can do.
Has anyone had this problem or have any idea what it could be?
Thanks for your help.
Jim Port 01-01-2013 04:53 PM
Have you checked to see if a GFI has tripped? These are common on receptacles in garages and for exterior receptacles.
dmxtothemax 01-01-2013 05:15 PM
you dont say if the outlet that the trickle charger was plugged into still works ?
The light in the garage could be on a different circuit to the outlets.
So most likely is a tripped gfci !
or loose connecttion.
Do you know the wiring lay out ?
And where the non functioning oulets get there power from ?
Is it a dedicated breaker ?
Or is it tacked onto an existing circuit somewhere ?
StarStryker11 01-01-2013 05:16 PM
..... Your a freaking genius and I am an idiot. THANK YOU!!! That was it. It looks like that all my outlets are connected. I have one GFI outlet in the garage and of course it has to be the one outlet that I'm never around and never use.
Jim Port 01-01-2013 05:25 PM
All donations to the genius fund graciously accepted. :laughing:
