Lights Suddenly Tripping Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 12:59 PM   #16
liscenced electrician
Rewards Points: 538
Originally Posted by MontyP View Post
Thanks gents.
The receptacle is not switched and no wiring or other electrical work has been done since the house was built in 2001.
For my own edification what is a "dead short"?
The same as a regular short with an extra word added in for emphasis. It may have some definition I don't know but it effectivly means the same thing. When current can make a complete circuit without going through any resisting load, aka, wires touching or something hooked up wrong
Ah, i guess they do have different definitions. A short circuit is just when current is able to go on an unintended path. This doesn't necessarily mean it is a 0 resistance path. This could be as simple as a small amount of current leaking to ground. A dead short is what we normally think of as a short. When there is a direct path back, with negligible resistance.
jimmy21 is offline   Reply With Quote
Old 10-24-2011, 02:23 PM   #17
Hi All,
I just spoke to my wife. The electrician has come and gone.
Apparently there were two wires touching in one of the light fixtures. It looks like some electrical tape had come off. The good news is there are no raccoons or squirrels in the roof chewing through my wiring and the builder had done everything properly (including having each fixture connected to its own box - a step apparently some omit).
It appears to be pure coincidence that this came to light at almost the exact moment I hooked up the new TV.
Thanks again to everyone for the advice. Much appreciated.
MontyP is offline   Reply With Quote
Old 10-24-2011, 02:26 PM   #18
Rewards Points: 6,652
Electrical tape should never be used. Any connections should have wirenuts holding them together.
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 04:06 PM
sump pump keeps tripping breaker after about 5 minutes of running DanDaMan Electrical 9 04-21-2011 11:32 PM
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
