Lights Stop Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 06:48 PM   #1
lights stop working
my living room lights and outside door light stopped working. they are on the same double switch plate.....also my light next to my living room stopped as well on a different switch............checked the breakers and everything ok.....still turned them on and off just to make sure............any suggestions?
thanx
mrleep25 is offline   Reply With Quote
Old 11-25-2011, 07:19 PM   #2
dannyoung85's Avatar
Do you have any GFCI outlets on that particular circuit? I would try resetting them if you do.
dannyoung85 is offline   Reply With Quote
Old 11-25-2011, 07:19 PM   #3
biggles's Avatar
you need to pop the plate and pull the switch out so you can METER read the terminals. FIRST...raw copper wire there check the switch terminals to it all BLACK WIRES. if you get 115V no matter the position of the switch means you have power coming in....now to test to see if you have neutrals WHITES WIRES one lead on a hot wire then test each WHITE you should have 115Vs also if you go from BLACK to whites.if NO POWER your neutral is missing from the feed into the switch plate area
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 03:31 AM
After replacing a light fixture the fan is not working but the lights do aniamaja Electrical 9 07-14-2011 08:23 AM
Half of outlet stop working! WHY?? drad88 Electrical 5 06-23-2011 11:36 AM
Christmas Lights airon26 Electrical 7 05-30-2011 10:58 PM
Hardly any air blowing out vents and lights dim every few minutes girlnamedjo HVAC 7 05-26-2011 12:29 PM
