Lights For A Shower... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2007, 07:25 AM   #1
RippySkippy's Avatar
Lights for a shower...
We have a shower with a roof the type that's the wall material formed up and over the shower....and have decided to put some sort of lighting into the shower roof, as it's really dark.
I'm at a bit of a loss as I don't have first hand knowledge of what light style looks good installed and is functional. I will tie into the exhaust fan circuit so the light(s) will be on when the fan's running and will replace the ceiling fan breaker with a GFCI.
What's your thoughts?
Rip
Last edited by RippySkippy; 07-24-2007 at 09:03 AM. Reason: changed ceiling fan to exhaust fan
RippySkippy is offline   Reply With Quote
Old 07-24-2007, 07:41 AM   #2
Licensed Pro
Ceiling fan? Do you mean exhaust fan? Please describe this "roof" in more detail.
Usually shower lights are either recessed fixtures with an enclosed cover or integral exhaust fan/lights.
Old 07-24-2007, 08:19 AM   #3
Yes it is an exhaust fan with a light. Here's a link to the tub/shower.
Old 07-24-2007, 11:47 AM   #4
Licensed Pro
Do you have access above the shower enclosure? You may be able to mount a recessed fixture. You may also want to look into low voltage or LED lights that are approved for wet locations.
Old 07-24-2007, 12:18 PM   #5
I do...it's completely open....I've been looking at some of the recessed...I haven't run across the LED versions yet...you wouldn't have a link would you?
Old 07-25-2007, 02:40 PM   #6
retired
Make sure the light you choose is UL listed for wet locations. That will dramatically reduce the selection available.
dmaceld is offline   Reply With Quote
Old 07-28-2007, 01:42 PM   #7
Yeah safety is a must.See that tey r for wet places
HiFi is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 01:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
installing lights in shower stall mcvane Electrical 2 03-30-2007 06:34 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 09:23 AM
