Lights And Outlets Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 07:56 PM   #1
Lights and Outlets Wiring
I am building brick columns for my fence around my pool. I want to put lights on each column and outlets on some of the columns.
How do I run a circuit to keep the outlets hot all the time, but control the lights with one switch?
toolguy is offline   Reply With Quote
Old 05-17-2009, 08:10 PM   #2
You need to run 2 seperate circuits because the receps will have top be gfci prootected and can't share a neutral with the lights.
Power
:.....switch...........light..............light... ....light.........light
:..........GFCI recep.......recep..................recep
220/221 is offline   Reply With Quote
Old 05-17-2009, 08:18 PM   #3
Power
Wow! Thanks for the quick reply. I was hoping I could do this without running two separate wires, but two I will do.
Thanks....
Old 05-17-2009, 08:26 PM   #4
Rewards Points: 2,350
You can do it with one circuit. You should GFCI protect the lights as well as the receptacles. You will need 4 wires: a constant hot for the recepts, a switched hot for the lights, a neutral and ground shared between them. You could use a GFCI breaker or faceless GFCI to protect the whole circuit, that way you won't have a shared neutral problem down stream.
Old 05-17-2009, 08:35 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
How close are the columns to the pool?
Old 05-17-2009, 08:52 PM   #6
Possibly you know this but there are requirements for outlets & lights. Lights also can't overhang the pool by a certain distance
Old 05-17-2009, 09:00 PM   #7
Scuba, that may be an outdated graphic from Mike Holt. I have never heard of this exception.
The ONLY receptacle allowed within 5'-10' of the pool is a pump or filter receptacle. ALL others must be at least 10' away.
Old 05-17-2009, 09:38 PM   #8
Yes, that appears to be an old pic
It's what my Inspector checked on when I added on to my pool cabana. He wanted an outlet added - as there isn't one in the pool area, only in the cabana
Good idea to read it all over for 2008
680.8 lists the clearances for pools ( I think ?)
680.22 lists other requirements
680.22 (3) 2008 states one gen purpose required between 6' & 20' from pool ??
I was thinking over 10' from the edge of the pool
So things have changed or am I missing again?
Old 05-17-2009, 09:43 PM   #9
Thanks guys for your info.
The lights/outlets will be in compliance either way. Each column is 10-12 feet away from the water. Also it will be protected by a GFCI breaker at the sub panel.
OK now, to the poster who said I could use one circuit. You mean like 14/3 w/grd?
The lights I have picked out are the new LED lights for outside "lanterns" so amperage will not be a concern.
Old 05-17-2009, 09:48 PM   #10
Yeah, you can use a 14/3 (12/3, or conduit) and have one hot wire switched for the lights.
Old 05-18-2009, 12:54 PM   #11
True, if the lights and receps are on the gfci a 3 wire circuit will work. This might make sense depending on the layout.
Black = hot
Red = switched
White = neutral.
Power source
:2wire
GFCI
:2 wire
switch
:3 wire
:..........recep (blk/wht)........light(red/wht)..........recep........light....
Old 05-18-2009, 07:57 PM   #12
Black = hot
Red = switched
White = neutral.
Power source
:2wire
GFCI
:2 wire
switch
:3 wire
Thanks guys. All of you have been great and I intended to do some trial and error to get the rest done, but you guys have been so cooperative, I will explain further what I would like to do.
I am running the power for both lights and recepticals from a GFCI breaker in a "logic box" that has a sub panel. The "logic box" allows you to push a button on the "menu" board to turn on the pump, underwater pool light, salt generator, pool heater, etc. separately. It also has a "remote control" option which I intend to use without having to go to the "logic box" each time I want to operate a device.
Naturally, I don't want to kill the power on the recepticals by pushing the column lights button to turn them off. Will I have a problem using this setup keeping the outlets "hot" all the time? Hope I'm not asking too much.
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
Wiring Problems sunici Electrical 18 04-26-2009 08:27 PM
Dead Outlets & Lights JnWaco Electrical 14 03-03-2009 11:08 AM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 09:19 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 12:16 AM
