Lights/outlets Stopped Working - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 09:37 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 654
Originally Posted by kh541 View Post
I've reset all the breakers, and have mapped almost all of them to their circuits. There are 3 breakers whose circuit I can't locate, including the circuit that contains the lights/outlets that have no power. Based on the layout of the breakers and the circuits, I'm pretty sure I know which breaker leads to the circuit in question.
Is testing this breaker a good next step in troubleshooting the problem? I see numerous online instructions for testing a breaker. Your thoughts?
Thanks!
If you have traced everything back as far as you can, then check the breaker and eliminate that as a problem.
jbfan is online now   Reply With Quote
Old 01-20-2013, 11:52 AM   #17
Child Alert! Pull Up!
fltdek's Avatar
Consider checking the wall switch, if you haven't eliminated that yet as the potential problem, again, check all the connections, check any wires in the box with wire nuts to make sure they are secure and tight.
fltdek is offline   Reply With Quote
Old 01-26-2013, 07:18 PM   #18
Thanks. Now that the weekend is here, I'm working on this again. I've re-checked all the connections in the switches and outlets, and I've also swapped out the breaker with one that is working fine on a different circuit. Still no power to the circuit.
One question though. From having removed my ceiling fan, I have the hot, neutral, and ground wires sticking out of the hole in my ceiling. Do I need to hook the ceiling fan back up in order to continue troubleshooting? Or is it OK to keep trouble shooting with the wires not hooked up? (Yes, I know not to mess with them when the power is on. They're up high and out of the way.) I'm curious to know if having nothing hooked up to the wires will prevent the other points on the circuit from working.
I've also found that we have one more outlet that may be on this circuit. It's buried behind some bookshelves that we'll have to move.
kh541 is offline   Reply With Quote
Old 01-26-2013, 09:39 PM   #19
fltdek's Avatar
As long as there are no wires junctioned in the ceiling fan box, having the ceiling fan dismounted will not affect anything.
Old 01-26-2013, 09:48 PM   #20
Ok. Thanks. I'll get to work on the bookshelves.
Old 01-26-2013, 09:50 PM   #21
fltdek's Avatar
If your to the point where you have pretty muched ruled out the outlets, switches, breakers ect...my next suspicion would possibly be squirrel or something chewing through a wire in the attic or crawl space. I dont know the style of your home (weird if I did....lol) meaning, that is there attic space above the room in question? Have you had any problems or noticed critters in the attic? Just something to consider?
Old 01-26-2013, 10:02 PM   #22
You don't know my house layout??? I guess you're not quite as much of a rock star as I thought. Ha! We've got a 2 story house, and the room in question is on the second floor. I was up in the attic today tracing wires and didn't see any evidence of critters.
Old 01-26-2013, 10:10 PM   #23
fltdek's Avatar
[QUOTE=kh541;1102830]You don't know my house layout??? I guess you're not quite as much of a rock star as I thought. QUOTE]
I probably wouldn't last 30 seconds on "killer karaoke" lol
Old 01-26-2013, 10:14 PM   #24
fltdek's Avatar
Do you have power into your light switch, meaning if you pull the switch out, with a tester, determine if any wires are hot?
Old 01-26-2013, 10:47 PM   #25
I tested one of the outlets and also the wires for the ceiling fan with my neon circuit tester. No power. Or are you meaning with a non-contact voltage tester?
Old 01-26-2013, 10:57 PM   #26
fltdek's Avatar
Yes, that would be a start, just to identify if power is present. Just keep in mind, as difficult as it is for you to trouble shoot this while you are there, its 100x's more difficult for us, not being able to see or guess how your rooms are wired or joined together. So, if we ask something that you may have already done, its only because (me personally) trying to image everything....so my apologies in advance.
Old 01-26-2013, 10:58 PM   #27
fltdek's Avatar
Have you noticed any other outlets in any other rooms that have stopped functioning?
Old 01-26-2013, 11:02 PM   #28
fltdek's Avatar
Another question i may ask, has there been any thing such as nails, screws or of the such, say to hang something on the wall prior to your problem, that may have pierced the wiring in the wall?
Trane Outside fan stopped working - cap or relay? JAWyrick HVAC 2 07-12-2011 11:03 AM
Water Dispenser Stopped Working dgoldb1 Appliances 20 05-16-2011 05:48 PM
Heat Pump Fan Has Stopped Working TurboSteve HVAC 2 12-15-2010 12:40 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 09:47 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 06:51 PM
