Lights On... No Power To Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 08:56 AM   #1
DRM
Lights on... no power to switch
Have hall lights controlled by 3 way switches. The problem is one day I turned the lights on and now neither switch will turn lights off. Replaced both switches...no power to switches and lights are still on?
DRM is offline   Reply With Quote
Old 08-26-2011, 10:43 AM   #2
Master Electrician
Rewards Points: 3,964
Tell us the WHOLE story and maybe we can help.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
DRM (08-26-2011), gregzoll (08-26-2011)
Old 08-26-2011, 10:54 AM   #3
Rewards Points: 6,652
I am thinking brric, that someone has been playing with some lights, and messed things up. Of course, there is that rare possibility that a switch went bad, but that would be far fetched.
The Following User Says Thank You to gregzoll For This Useful Post:
DRM (08-26-2011)
Old 08-26-2011, 10:56 AM   #4
DRM
Sorry, don't know what else to tell you....turned lights on and won"t turn off....tested wires at both switches and no power at either switch. Have to have connections in a junction box buried somewhere because there are only three wires at each switch with no other wires connected in either box and the light fixtures only have a hot and neutral in each ceiling box!
Old 08-26-2011, 11:20 AM   #5
DRM
gregzoll, no one had touched the lights and I replaced both switches thinking that was the problem...there is no power coming to either switch!
Old 08-26-2011, 11:23 AM   #6
If you replaced the switches, then yes that is where the problem is. Post pictures of the switches how you wired them.
Old 08-26-2011, 11:32 AM   #7
Master Electrician
You say hall lights, as in plural. How do you know there is only two wires at the fixture(s)?
Old 08-26-2011, 11:49 AM   #8
DRM
Lights would not turn off before I replaced the switches...were working fine ..then one day they would not turn off. Dropped fixtures down from ceiling boxes so I could check wire connections that is how I know what wires are there.. No power coming to the switches !
Old 08-26-2011, 11:52 AM   #9
Something happened to cause the lights to stay on. They do not just turn on all by themselves. Do you own or rent this place?
Old 08-26-2011, 11:56 AM   #10
DRM
Wire exactly as the ones that were replaced marked all wires....just don't get why no power in any wires coming to switches.....could it be bad connection wherever these are tied together in a junction box?
Old 08-26-2011, 11:56 AM   #11
Master Electrician
There doesn't have to be power at the switches if the power is at the fixture.
Old 08-26-2011, 11:58 AM   #12
Master Electrician
Yes, in the fixture j-box.
Old 08-26-2011, 12:04 PM   #13
DRM
Didn't turn on by them selves....turned on and then would not turn off with either switch...own home but is obvious previous owner did some creative wiring on his own....home over 100 years old with some upgrades...but have no idea where he might have tied the power in for these switches...not at fixtures and not at lights....has to be a junction somewhere behind walls or in ceiling!
Old 08-26-2011, 12:06 PM   #14
DRM
Would it be a problem with the neutral somewhere?
Old 08-26-2011, 12:07 PM   #15
Master Electrician
If you remove both switches are the lights still on?
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Indoor switch for outdoor motion activated security lights youngdoc Electrical 5 12-02-2010 02:07 PM
3-way switches, lights, and a photoelectric switch. Your thoughts? Fox Electrical 7 11-23-2010 10:08 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
2 lights one switch, power to the switch . . . gregoryc Electrical 15 03-17-2009 10:46 PM
