Old 05-21-2012, 04:33 PM   #1
Lights inside tub & shower?
Have never had this before. There are recessed lights in the actual shower stall and also, in the other bathoom, there is a light straight over the tub.
Is this common? I'm not comfortable with this electricity over damp wet places with water splashing all around.
Startingover is online now   Reply With Quote
Old 05-21-2012, 04:45 PM   #2
Licensed Electrician
k_buz's Avatar
VERY common. As long as there is an enclosed trim and gasket installed you are good to go.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Startingover (05-21-2012), Thurman (05-21-2012)
Old 05-21-2012, 07:24 PM   #3
Household Handyman
Very common indeed, and I have made good monies putting these in. The key to this type installation, as stated, is an approved light fixture with proper trim/gasket. This is considered a "damp proof" installation versus a "wet proof" installation where the fixture would be subjected to a lot of water actually hitting the fixture. It's just amazing the things you will find in your shower once you have add direct lighting.
Old 05-22-2012, 12:09 AM   #4
" Euro " electrician
frenchelectrican's Avatar
I have done this all the time however there is a nice gotcha what most peoples miss this part when they install the shower recessed luminarie that have to be on GFCI ( it will be noted in the installment instruction ditto with fart fan as well )
You have to be carefull when you bring this thru the switch box to keep the GFCI circuit and non GFCI circuit seperated ( the key issue is you can not cross the netural on this one otherwise you will trip it as soon you hit the switch )
Merci,
Marc
Old 05-22-2012, 12:15 AM   #5
k_buz's Avatar
I have never put a shower recessed on a GFI and have never been required to by an inspector. Bath fans...yes...
Old 05-22-2012, 12:20 AM   #6
I almost got nailed with one of the inspector in Wisconsin but In France it pretty much SOP for me to run RCD ( GFCI ) for that arrangment.
Most inspector will have some leeway with GFCI with recessed luminaire but once you get over 8 foot IIRC ya are free on that.
Merci,
Marc
Old 05-22-2012, 01:20 AM   #7
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I usually put the light and bath fan on a lighting circuit am I doing it wrong?
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-22-2012, 08:31 AM   #8
french,
how do I know if my shower/tub recessed lights have GFI?
I know about the GFI at the sinks and how to test them, but where would it be located for the shower/tub? Or are they all tied onto the sink GFI?
Old 05-22-2012, 08:59 PM   #9
Licensed electrician
GFI protection can be in the form of a GFI receptacle, a deadfront GFI or a GFI breaker.
You could trip the GFI and see if the lights go out.
RR, that is a typical way to wire the fans and lights.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (05-22-2012), PaliBob (05-23-2012)
Old 05-23-2012, 09:50 PM   #10
Jim,
tripping the gfi to see if the lights go out.........I wouldn't have thought of that. THANKS.
Old 05-24-2012, 07:42 AM   #11
kbsparky's Avatar
You are not required to have GFCI protection on lights over the tub/shower unless that manufacturer specifies it.
Most exhaust fans do have such a requirement, however.
I'd opt for a sealed LED trim over the tub in any case.
-KB
Old 05-24-2012, 08:33 AM   #12
kb,
By sealed are you saying there's lights available where the actual bulb isn't exposed, but protected by a shield or piece of plastic? If so, it sounds easy enough to have an electrician change them. THANKS!
Old 05-24-2012, 08:55 AM   #13
Just look for a shower rated trim from the same brand as the recessed housing.
BTW, some open bulb trims are shower rated with the correct bulb.
Old 05-24-2012, 09:07 AM   #14
thanks jim,
Seems I've been going to the building store every day.
Old 05-24-2012, 10:24 PM   #15
kbsparky's Avatar
Originally Posted by Startingover View Post
kb,
You can change them yourself.
Here is one example:
-KB
replacing wet wood under linoleum in front of shower stall Pawl Building & Construction 7 01-01-2012 04:11 AM
is water conservation inside the shower head or the shower hose? vcreation Plumbing 1 11-11-2011 07:20 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 10:15 PM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
