-   -   Lights inside tub & shower? (http://www.diychatroom.com/f18/lights-inside-tub-shower-144455/)
Startingover 05-21-2012 03:33 PM
Have never had this before. There are recessed lights in the actual shower stall and also, in the other bathoom, there is a light straight over the tub.
Is this common? I'm not comfortable with this electricity over damp wet places with water splashing all around.
k_buz 05-21-2012 03:45 PM
VERY common. As long as there is an enclosed trim and gasket installed you are good to go.
Thurman 05-21-2012 06:24 PM
Very common indeed, and I have made good monies putting these in. The key to this type installation, as stated, is an approved light fixture with proper trim/gasket. This is considered a "damp proof" installation versus a "wet proof" installation where the fixture would be subjected to a lot of water actually hitting the fixture. It's just amazing the things you will find in your shower once you have add direct lighting. :thumbup:
frenchelectrican 05-21-2012 11:09 PM
I have done this all the time however there is a nice gotcha what most peoples miss this part when they install the shower recessed luminarie that have to be on GFCI ( it will be noted in the installment instruction ditto with fart fan as well )
You have to be carefull when you bring this thru the switch box to keep the GFCI circuit and non GFCI circuit seperated ( the key issue is you can not cross the netural on this one otherwise you will trip it as soon you hit the switch )
Merci,
Marc
k_buz 05-21-2012 11:15 PM
I have never put a shower recessed on a GFI and have never been required to by an inspector. Bath fans...yes...
frenchelectrican 05-21-2012 11:20 PM
I almost got nailed with one of the inspector in Wisconsin but In France it pretty much SOP for me to run RCD ( GFCI ) for that arrangment.
Most inspector will have some leeway with GFCI with recessed luminaire but once you get over 8 foot IIRC ya are free on that.
Merci,
Marc
rrolleston 05-22-2012 12:20 AM
I usually put the light and bath fan on a lighting circuit am I doing it wrong?
Startingover 05-22-2012 07:31 AM
french,
how do I know if my shower/tub recessed lights have GFI?
I know about the GFI at the sinks and how to test them, but where would it be located for the shower/tub? Or are they all tied onto the sink GFI?
Jim Port 05-22-2012 07:59 PM
GFI protection can be in the form of a GFI receptacle, a deadfront GFI or a GFI breaker.
You could trip the GFI and see if the lights go out.
RR, that is a typical way to wire the fans and lights.
Startingover 05-23-2012 08:50 PM
Jim,
tripping the gfi to see if the lights go out.........I wouldn't have thought of that. THANKS.
kbsparky 05-24-2012 06:42 AM
You are not required to have GFCI protection on lights over the tub/shower unless that manufacturer specifies it.
Most exhaust fans do have such a requirement, however.
I'd opt for a sealed LED trim over the tub in any case.
Startingover 05-24-2012 07:33 AM
kb,
By sealed are you saying there's lights available where the actual bulb isn't exposed, but protected by a shield or piece of plastic? If so, it sounds easy enough to have an electrician change them. THANKS!
Jim Port 05-24-2012 07:55 AM
Just look for a shower rated trim from the same brand as the recessed housing.
BTW, some open bulb trims are shower rated with the correct bulb.
Startingover 05-24-2012 08:07 AM
thanks jim,
Seems I've been going to the building store every day.
kbsparky 05-24-2012 09:24 PM
Originally Posted by Startingover (Post 927761)
kb,
You can change them yourself.
Here is one example:
http://images.lowes.com/product/conv...35706448xl.jpg
