Lights Got Dim, Low Voltage? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 12:59 AM   #1
Lights got dim, low voltage?
We had a 2 day blackout due to the recent storm by Irene. We've had power back for 2 days now. When we got home today, it seemed that most of our lights were not as bright as normal. The coffee maker would not light up, and the microwave took over twice as long to heat. TV works fine.
The power co says that their end is OK and it's "our problem", and we need an electrician. What could possibly be wrong besides the power company not providing enough voltage and a "brownout"?
menton1 is offline   Reply With Quote
Old 09-04-2011, 01:43 AM   #2
Thadius856's Avatar
Rewards Points: 504
I would agree with you that it sounds like it's on the poco's end.
Are any of your neighbors experiencing this?
Thadius856 is offline   Reply With Quote
Old 09-04-2011, 08:01 AM   #3
Rewards Points: 1,442
Have you measured the voltage from each of the hot wires to neutral in the panel (or between the prong holes in many different receptacles)?
Old 09-04-2011, 08:32 AM   #4
biggles's Avatar
if your neighbors have the same problems its the power company,but get the top of your CB panel read to see if it 208/230 on the pole feed..sounds like everything is dragging like in a brown out....
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Outdoor lights (Soffit etc) DIY_JC Electrical 2 09-25-2009 12:45 PM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
