Lights Flashing After Replacing 2 Fixtures On Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 07:04 PM   #1
Lights flashing after replacing 2 fixtures on circuit
Hey I'm new to this site and am hoping there is an easy fix to my problem. I just replaced 2 flush mount ceiling fixtures in a hallway. They are both operated by the same switch. The old fixtures were working fine, but after installing these and turning the power back on they start blinking within 10 seconds. The fixtures had speed clips which I was able to use on one fixture, but had to cut off the other because there were two supply wires. Any thoughts??
girlnextdoor is offline   Reply With Quote
Old 01-23-2011, 07:14 PM   #2
DIY staff
Rewards Points: 7,174
Try smaller bulbs--sounds like the thermal overload switch is kicking off.
When they blink off do they both go off at the same time?
Old 01-23-2011, 07:23 PM   #3
They both blink at the same time, almost like rapid fire flashing and it makes a faint noise that I can here both near the lights and in the basement be the electrical box. I have 60 watt compact florecents in them and the fixtures are rated to 75 watts.
Old 01-23-2011, 07:55 PM   #4
Shut the power off. Recheck all the connections. When I say recheck I mean take all connections apart and put them all back together.
If I had to guess....I bet you have a loose neutral wire in the light with the two feeds. But that is only a guess.
Are the noises like sparky type noises? Regardless don't go to bed tonite without leaving that switch OFF!!!! Loose neutrals = fire. Fire=bad
Andy-n-ATL is offline   Reply With Quote
Old 01-23-2011, 08:10 PM   #5
I rechecked once, as described, I guess I'll have to go back and try again. grrr. I wouldn't say the noises sound like sparks... more like a clicking that is in sync with the flashing. I just wish I could narrow it down to one fixture, then I might have a better idea what was causing it. But I took each one down while leaving the other up to test and they both had the same problem.
Old 01-23-2011, 08:47 PM   #6
Electrical Contractor
kbsparky's Avatar
Try regular bulbs. Does the same thing happen? Is the switch by chance a dimmer?
Another thought here ... these fixtures may be wired wrong, with the thermal overload wired in parallel instead of series. How many leads were in each fixture, and how did you connect them?
-KB
Old 01-23-2011, 09:10 PM   #7
Clicking sounds like thermal overload.
AndyinAtl is offline   Reply With Quote
Old 01-23-2011, 10:40 PM   #8
Scared Electrician
Saturday Cowboy's Avatar
second
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-24-2011, 07:13 AM   #9
Problem solved! I replaced the compact fluorescent bulbs with standard light bulbs and they are working like a charm. The lights are on a dimmer switch, so I guess what I've learned is that dimmers and compact fluorescents don't play well together.
Thanks for all the great (and propt replys)!
Old 01-24-2011, 07:27 AM   #10
Experienced
Jackofall1's Avatar
Well now you know, call the neighbors, pull out the old disco records and have a party.
Can I use lights and outlets on same circuit? heyd Electrical 4 08-24-2010 12:05 PM
Fluorescent & HPS fixtures on same circuit Mike2401 Electrical 4 03-02-2010 01:30 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Adding lights to a circuit.. Pl check circuit aw44 Electrical 4 08-27-2008 02:09 PM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
